Mpp
Mpp
Old 17th December 2011, 12:00 AM   #3671
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
why R15 set to 5k ?
RC
Old 17th December 2011, 03:22 AM   #3672
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
R15, R16 should be the same. Magic distortion cancelation ?
Old 17th December 2011, 05:27 AM   #3673
MiiB is offline MiiB  Denmark
my mistake should be 2.2K
Old 17th December 2011, 07:08 AM   #3674
Updated... Think most of the ooops's are taken out...
michael
Old 17th December 2011, 08:44 AM   #3675
FdW is offline FdW  Netherlands
FdW's Avatar
Mpp
R12/13 100u not 1, that is 1F?
Old 17th December 2011, 09:01 AM   #3676
hmmm that is what happens when you simulate deep in the circuit, you have to set the caps high, or completely remove them, Will set them back to right value later today....but where it say 1 its supposed to be 10mF
Old 17th December 2011, 09:01 AM   #3677
FdW's Avatar
Mpp
There is still a small improvement to be made. R17/R29 can be split in two (2 x 220) and from the center a capacitor could be connected to ground (470/1000uF). I know the power supply is very good, and this is not ‘needed’, but still…
Old 17th December 2011, 09:26 AM   #3678
FdW's Avatar
Mpp
And have a look at C3/4/8/9
Old 17th December 2011, 09:30 AM   #3679
Will add that...and post new schematic later toady.... to be clear I suppose you mean R27 and R 29.. True that takes even more noise out, and reduces the resistor current noise at the same time.. good thinking..! (again)
The C-3-4-8-9 is supposed to be 10mF and 3.3 Uf for decoupling, though the decoupling is not needed on a high impedance current mirror, I can still hear it, and if at Mundorf tinfoil cap is used it add's a pleasant calm warmth to the sound. ( just one of those things you can hear, but not explain)
Old 17th December 2011, 10:13 AM   #3680
FdW's Avatar
Mpp
Ooops... 27/29 yes
MppHide this!Advertise here!
