MPP
MPP
Old 16th December 2011, 06:56 PM   #3661
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
The 1N829 sadly costs a litte more.
preregulatorpeterE-MAIL
Old 16th December 2011, 06:58 PM   #3662
MiiB is offline MiiB  Denmark
I agree....will post it tomorrow...then we have a chance to sleep on it
Joachim will you do a perfbofeard..or is it tooo complex for that..??
According to the nice sweedish work i belive theres are more options to tha zener...maybe 3 of theese could do a good figure if run at 5 mA
BCX55/C3V9 (0.5W 3.9V):
#1 @ 1mA: 1.7 1.8 1.7 1.6 1.6 uV
#1 @ 5mA: 1.1 1.1 1.1 1.2 1.1 uV
#1 @ 20mA: 0.94 9.76 0.84 0.79 0.77 uV
#2@1mA: 1.6 1.6 1.6 1.5 1.6 uV
#2@5mA: 1.2 1.1 1.1 1.1 1.1 uV
#2 @ 20mA: 0.97 0.78 0.86 0.76 0.77 uV
Old 16th December 2011, 07:16 PM   #3663
sampler is offline sampler  Lithuania
Guys, don't loose your sleep over that reference. I think even LM329 decoupled for low FC would do the job. At least it has well documented noise over BW in datasheet, so 5uV wideband is realistic with right decoupling.
Old 16th December 2011, 07:23 PM   #3664
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I can build that, no problem. The PCB can be designed parallel . When i find problems i can report.
Old 16th December 2011, 07:28 PM   #3665
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
This is what I have. There seems to be 163MHz 1mV, but with the 'naked' circuit on the table I do think it is environmental. It is less than 1mV, right on the limmit of the scope.
Old 16th December 2011, 07:38 PM   #3666
Wow....amzing...
Old 16th December 2011, 08:09 PM   #3667
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Frans, what is the div/V?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 16th December 2011, 08:44 PM   #3668
FdW's Avatar
MPP
Rüdiger
2mV / Div
Old 16th December 2011, 08:49 PM   #3669
hesener is offline hesener  Germany
MPP
cool - this is progressing really fast. have time monday night to start working....
Old 16th December 2011, 08:58 PM   #3670
This is where I'am Now..Freeze...
Think that PCB and Perfboard can comence...
Wrong designation on two helper transistors, all should be BC327-337
By the way, that buffer looks awesome...don't know what to call it.. driven diamond cascode..??
michael
MPPHide this!Advertise here!
