Mpp - Page 352 - diyAudio
Old 13th December 2011, 08:04 PM   #3511
MiiB is offline MiiB  Denmark
I have adjusted the gain wit a fixed resistor to 55 dB...
The input voltage is 1 mV. Which is more than most high-end cartridges put out...frequency is 1k KHz.
Old 13th December 2011, 08:04 PM   #3512
Joachim Gerhard's Avatar
Frans, Michael was asking about a PSU but you have already posted it i think. When you see the latest circuit would you make any adjustments ? Anyway, could you please post your solution again please ?
Old 13th December 2011, 08:04 PM   #3513
Frans I better get in on the buy as well....
Old 13th December 2011, 08:07 PM   #3514
I would prefer 60dB. My Titan i gives out 0,5mV 5cm sec so we have 0,5V out. That is even not enough for some Ortofons and others.
Old 13th December 2011, 08:11 PM   #3515
I'll adjust the RIAA values to fit that, We lost 4-5 dB's in the degeration of the input...
a little scaling will do.....
M
Old 13th December 2011, 08:11 PM   #3516
FdW is offline FdW  Netherlands
FdW's Avatar
Originally Posted by Joachim Gerhard View Post
Have you already simulated that whole schebang ?
I think Frans is our PSU man and he has drawn up something before.
Please Frans, jump in if you like when your read this.
Still working on the final version (there is a (small) one wire change). I will publish in the next hour.
About the servo, normally I would use a somewhat bigger capacitor (1u poly) and smaller resistors 1Meg or even 100K. My opamp of choice for servos is the OPA134 (like D.Self )
Old 13th December 2011, 08:12 PM   #3517
I use the OPA134 too. No problem with sound or function and easy to get.
Old 13th December 2011, 08:17 PM   #3518
the cap is 1u and the input resistor is 1 Meg and the output is 2x2meg in parallel..
Old 13th December 2011, 08:18 PM   #3519
FdW's Avatar
Sorry Joachim one small change to make, the capacitor that was placed between the transistor base and ground has been moved to (between) transistor base and output. This gives a much improved load response.
Attached are may (currently final) research and power supply schemas with annotations. Also attached are the LTspice source files. Next thing for me (is build the real thing).
There are a positive and a negative supply and one variation that uses (almost) the same components for the negative supply as for the positive.
Also note that BC327 and BC337 transistors can be used to replace the BC550 and BC560.
And finaly, if you want more than 100 mA you should replace the single transistor (in the gyrator) with a Sziklai pair having a Rcb of about 100 Ohm. (more usage for your BC327 and BC337 transistors).
Old 13th December 2011, 08:20 PM   #3520
Sure, Michael. You gain in lower distortion and you loose in gain. That`s life.
Copyright 1999-2017 diyAudio
