MPP
The XCEN is a balanced to unbalanced converter that i designed with EUVL. Actually i did not design much but had the idea for the input stage. You may remember the time when Sampler was more active here. I had shown that idea to convert from balanced to unbalanced right at the input.
The XCEN design is a folded cascode though like the Blowtorch and does not use mirrors.
The circuits works in my place and we have a PCB but i am still fine tuning it.
The XCEN can also be used after a balanced I/V stage in a DA converter.
There are good integrated solutions from Thats for example but we wanted something discrete.
Joined 2006
Joined 2006
Yes.. amtrans.. They sound ok but I will never use those again as they differ more than 20% from spec and present great variations between samples.
The yellow cap is my fav... Polystyrene on tin foil... quite juicy stuff.
The vertical trim pot I use for cart load is a bulk metal from vishay... quite good.
The 6800u caps are FR and the others are 2200 FM + 470u BG
I am currently rediscovering my LP collection... incredible mixture of detail and integrity.
