What is the capacitance range ?That should work like a charm - don't know why but I was envisioning something like this:
Nice scope, Frans.
That cap looks cool, Hesener.
I was attracted to it due to its 12bit vertical depth possibility and the large screen.
Analog digital converter (A/D)
12 Bit at ≥ 5 µs/div
8 Bit at ≤ 2 µs/div
And I did order
Rigol DS2102 DSO !!Special offer!!
Agilent like refresh and screen. If it will prove itself as the 1052 did, it looks like a new hit.
Just finished and fired the Paradise... Not again !!!
I have got one channel working perfectly and the other one outputs 15V
Where should I start ?
Changing opamps does not alter the situation.
And I did order
The guys at the ATL have bought 1set (anonymous) and are planning to use the triplicator Triplicator - Red Dwarf Wiki - Tongue Tied on it
As I said do not use triplicator there may be same disavantagges
And I did order
How high is the assembly including heatsink?
There goes any fantasy of a balanced MPP set with a floating RIAA
You need at least 5cm of height inside.
Two grilled chicken in each mouth a day ?
Mr Gerhard,
at least it will be Privat-Paradies
I can't think of any examples of balanced phono stages with true dual complementary inputs, let alone with twice the already sturdy power consumption of a single-ended board.
(maybe two quails each day, with varying sauces, not just truffle and foie gras)
