MPP
MPP
Old 26th November 2011, 06:44 AM   #3171
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Joachim, we are dearly missing you at ETF!
Had the turntable shoot-out yesterday.
As always, great equipment, great people, great presentations.
Rumour has it that it will be in Germany next year.
jan didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 26th November 2011, 10:08 PM   #3172
jan.didden's Avatar
Frank Schroeder won the turntable shootout. And yes, Berlin is confirmed.
jan
Old 26th November 2011, 10:15 PM   #3173
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Did he have the new tangential arm ?
Old 26th November 2011, 10:18 PM   #3174
tabams is offline tabams  Netherlands
Default Graphic EQ
Originally Posted by Joachim Gerhard View Post
Joachim,
Very interesting and useful links you gave me (us), thanks
Old 26th November 2011, 10:22 PM   #3175
Yes, that equalizer will work with some modifications. Just shift the midrange EQ to 3kHz,
the bass EQ a little deeper and the treble EQ up to over 10kHz. As far as i can tell you should only change the values of the caps. So in the midrange you should use 1/3rd of the value that is given for example. Just put this circuit behind my input stage. You can take even out the inverter but then you have to revers your speakers.
Old 26th November 2011, 10:26 PM   #3176
This is the circuit and the formulas :
Old 26th November 2011, 10:35 PM   #3177
So :
2 x C3 = 0.1uF
1/3 C4 = 1.66nF
1/3 C5 = 7.33nF
1/2 C6 = 2.5nF
i think the exact values are not critical.
Old 26th November 2011, 10:54 PM   #3178
hesener is offline hesener  Germany
MPP
yes, it was a quasi-tangential arm and it was great! mood was great too, except my own little frustration, having fried the motor of the EMT928 i wanted to participate with in the shootout, so i arrived without it and without the starless (because i tried to fix the table), but its almost done. more later.....
Old 26th November 2011, 11:06 PM   #3179
I am very curious how the Starless sounds against the FPS. The circuits could not be different. Yes, Frank is the champion. He comes up with miraculous things. I am very happy that there is such life in vinyl. For tomorrow i plan a listening session with the Tanzmusik. The EQ has already proven to be a good thing. It is amazing how different records can sound when you make small changes to the frequency response. I used a Cello Palette for some time so i know what can be pushed out of unassuming recordings.
Old 26th November 2011, 11:12 PM   #3180
In the active 3 way Baxandall resistors R1, R2 are much too high for my taste. They add a lot of noise. I think 10k is better.
When you do not change component values of the EQ stage you can mimic RIAA by fully advancing the bass EQ and fully pushing down the treble EQ, mid EQ in middle position.
A simple linear low noise amp in front of it would give you much of what the Tanzmusik can do. The first inverter stage could be redesigned as a Phono Clone and then you are done. A variable RIAA phono stage.
MPPHide this!Advertise here!
