Mpp
Mpp
Old 5th November 2011, 12:01 AM   #3061
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Default transistors
I was thinking 2SA970 and 2SC2240 or BC550 and BC560.
And batteries
Can't wait!
atb,
Audiofanatic
Be nice to animals.
Old 5th November 2011, 12:05 AM   #3062
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That will work too.
Good luck.
Old 5th November 2011, 12:08 AM   #3063
MiiB is offline MiiB  Denmark
I look good, but can't see particular well...;-)
Old 5th November 2011, 12:09 AM   #3064
You should work as an actor (:
Old 5th November 2011, 12:20 AM   #3065
Default J-FET
Joachim,
What's the best IDSS for this circuit?
Audiofanatic
Be nice to animals.
Old 5th November 2011, 05:19 AM   #3066
I would use BL grade ( Idss ca. 8mA ). My circuit degenerates that to 6mA. That is about optimum for least distortion. In a line stage there is no need for sub nV noise so we can afford some degeneration.
Old 5th November 2011, 05:21 AM   #3067
There is a very symmetric N and P channel pair from NEC that EUVL found that should also work well in my circuit. I just forgot the names.
Old 5th November 2011, 06:39 AM   #3068
EUVL is offline EUVL  Europe
You mean 2SK163 / 2SJ44 ?
It is even more impossible to get than the Toshiba's.
I ordered a few pairs as NOS fron Japan and had to pay a premium for those.
Patrick
Old 5th November 2011, 01:19 PM   #3069
That was what i am afraid of. When i look at the NEC-Tokin website they do not make transistors any more.
Old 5th November 2011, 01:35 PM   #3070
What can work is 2SJ103BL and 2SK246BL. If we degenerate them to 3mA we need a 900
Ohm trimmer and the drain resistors should be 2.5kOhm. That way we lower the gain of the input stage compared to the 2SJ74, 2SK170 combination. That could help linearity. What i do not like is the wide spread of Ugs with this Fets. The 2SJ103 needs 2.2V and the 2SK246
needs only 0.5V to degenerate to 3mA. So a conflict can arise between the output offset trim and the zero trim in distortion. Maybe i am wrong here because when both Fets drop 3mA over the drain resistors output offset should be fine even when the trimmer is a lot off from the mid position.
MppHide this!Advertise here!
