Mpp
Mpp
Old 12th October 2011, 11:37 AM   #2851
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Yes, Ricardo. The loading resistors or additional caps fit into the Neutriks. I use 2 x 300 Ohm with the Lyra Titan i and sometimes with a 1 to 10nF cap in parallel. The Rauschfrei Stage itself is factory equipped with 2 x 100kOhm. Natural input impedance is even much higher because i use J-Fets at the input that are hold under 4V from drain to source.
Under this conditions there is virtually no gate current so input impedance without loading in in the GigaOhm range, maybe even higher. This circuit could be used for brain scanners and the like to retrieve tiny signals.
Old 12th October 2011, 11:49 AM   #2852
SOUND_Rays is offline SOUND_Rays  Slovenia
SOUND_Rays's Avatar
Thumbs up True "Ballanced" is the only way to the best possible sound
Originally Posted by Joachim Gerhard View Post
The circuitry is fully balanced from input to output
Congratulation on a decision, and to unseen all hard work to achieve this final I suppose very fine sounding Vinyl playback preamplifier
All the best with it . . .
Old 12th October 2011, 11:52 AM   #2853
Yes, fully balanced done give the best sound in system. It is accurate and musical.
Old 12th October 2011, 12:15 PM   #2854
reinhard is offline reinhard
It is now a Fet-Tube hybrid cascode like the Arthur Loesch circuit.
Original Arthur Loesch is a single WE417 in common cathode mode.
Think you are talking about Thorsten Loesch´s variations of that circuit.
Reinhard
Old 12th October 2011, 12:16 PM   #2855
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Your decision to use four Riaa circuits is the best choice IMO.
RC
Old 12th October 2011, 12:34 PM   #2856
Morgan Jones and Allen Wright prefer single RIAA networks between phases.
Me too, for good reasons.
Reinhard
Old 12th October 2011, 01:28 PM   #2857
nhinstruments
RCruz's Avatar
Mpp
I also prefer single Riaa passive circuits between amplifying stages but two Riaa stages per channel to create a balanced Riaa is the way to go IMO.
The only issues I see is if we need to add a sut, the loading becomes troblesome.
Hi JG... did you source the proto case from Italy ?
RC
Old 12th October 2011, 01:57 PM   #2858
jam is offline jam  United States
jam's Avatar
Joachim,
I see you have been hard at work.....................nice job .
Jam
Old 12th October 2011, 02:20 PM   #2859
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by reinhard View Post
prefer single
Maybe a somewhat North-European preference ?
Me Thorens TD550 (SME312, the Nobile clone tonearm came out later), Classé Omega phono (RIAA part dual and part floating between phases), Classé Omega MKIII line, all balanced.
The Rauschfrei looks/reads very tempting.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 12th October 2011, 02:43 PM   #2860
kamis is offline kamis  Serbia
Mr. Gerhard, there is only one pair of regulators inside preamp , so it is not fully dual mono PS, which could be improved.
What is shassis material? Gold plated jumpers are better than DIP swithces for adjusting cartridge input loading.
MppHide this!Advertise here!
Copyright ©1999-2017 diyAudio
