Mpp
Mpp
Old 11th September 2011, 07:58 AM   #2681
MiiB is offline MiiB  Denmark
I know it can be balanced so there's no DC out...my concern is thermal drift.....simulation is one thing reality another...and it just may be so that all balances out and all works brilliantly with no offset problem,,
if not i believe it would be good to mapped the means to isolate the possible drift...Ie by separation of the two stages or to add it at the output..
Old 11th September 2011, 10:18 AM   #2682
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Thank you Miib
Why do you call it oneshot ?
RC
Old 11th September 2011, 10:21 AM   #2683
the full riaa correction in one-bundle...enough gain to work with MC's...
Old 11th September 2011, 01:31 PM   #2684
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Post 2679, are you sure that the buffer fets will conduct without a gate current in the input fet ?
Old 11th September 2011, 02:57 PM   #2685
according to simulation there's is 15mA through.. and no problems in conduction....would you like positive potential..??
Old 11th September 2011, 03:10 PM   #2686
No, i just wonder if it works.
Old 11th September 2011, 04:22 PM   #2687
If you keep the 1Mohn to GND.. then to keep the RIAA-curve.. the resistor to GND must be increased to 400K..or the base response suffers..best would be if drift is not an issue and that the DC-cap is not needed...
Old 11th September 2011, 04:25 PM   #2688
Yes, the resistor value can be split. I did that before. We could of cause use a servo. More parts though and a discussion what sounds better : cap or servo.
Old 11th September 2011, 05:07 PM   #2689
let's see how it drifts......
A 100 nF cap can be of very very good quality...but will for sure make som kind of imprint and form some kind of signature on the circuit...but then again so will anything else also...
Old 11th September 2011, 09:37 PM   #2690
nhinstruments
RCruz's Avatar
Mpp
There are some inexpensive High Quality Teflon 100n caps available
These are very transparent sounding (for a teflon) and very extended.
Servo might be good but it would add to the complexity of the circuit.
RC
MppHide this!Advertise here!
Copyright ©1999-2017 diyAudio
