Mpp - Page 264 - diyAudio
Old 5th September 2011, 02:46 PM   #2631
MiiB is offline MiiB  Denmark
I personally think that a mosfet amplifier driving some sets of Bipolar current dumpers is a good way to deal with complex loads,, let en bjt's do the crude current work and then let the fine lateral mosfet amplifier deal with the finer voltage adjustments..this way I believe we can get the best of both worlds...
Old 5th September 2011, 03:01 PM   #2632
This is where a am right now....I have made a PCB..And will start to assemble when I have the last components here....It's basically an elaboration on Nico's take on Lazycats circuit...Show's some promise I think..
Old 5th September 2011, 04:07 PM   #2633
Joachim Gerhard's Avatar
Looks good to me. Nice transistors choosen. That in class a could be what i am searching for.
In the meantime i have being working on the PEN circuit a bit more. It sounds very good so i can recommend it as a quick fix. What came to my mind is an AIOG RIAA based on that but with a floating cascode input. i will draw something up and try it.
Old 5th September 2011, 04:44 PM   #2634
bandwith more than 10 MHz....almost DC to light...
Old 5th September 2011, 04:47 PM   #2635
That is what i like, its fast.
Old 5th September 2011, 05:05 PM   #2636
and very very good in distortion specter....The pcb I have made is without the bias network...as I have a feeling that a pure resistor-bias is enough to keep it thermally stable...as the negative temp-co of the laterals has a higher slope than the output btj's..If not Ill have to hard-wire it...
Old 5th September 2011, 06:16 PM   #2637
You will find out, sure.
Here is my AIOG PEN circuit. It looks a bit exotic even for me but it should work. The input stage is now my well known buffer, inverted and without the trimming resistors. I named the circuit Starless and Bible Black due to an article that Malkolm Hawksford wrote and is also a name of a Robert Fripp album.
The precision mirror has excellent DC stability so i hope i can use it without servo. The circuit is fully floating and needs a supply with one polarity only. If it works i plan to make a PCB this time.
Old 5th September 2011, 06:56 PM   #2638
interesting with the GND reference... good way to get DC-coupling......looks like an interesting concept..temp-co could give some DC float
It could be made all SMD..with the BF parts. small and compact..
Old 5th September 2011, 07:00 PM   #2639
Yes, that what i am thinking of. The bipolars could be BC850-860.
Old 5th September 2011, 07:51 PM   #2640
Hi Joachim
Clever circuit.
The mirrors can of course be improved a bit, I know that you can make them better.
Cheers
Stein
Copyright 1999-2017 diyAudio
