Mpp
Mpp
Old 19th August 2011, 05:05 PM   #2561
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Yes, with that trim you can null distortion. It also affects offset and when you have the right Fets you can null that with this trim too. It fluctuates a bit though because the Fets have a temp co. How does the Rabbit Hole sound and does it work properly ? I think it is a great circuit, a classic.
Old 19th August 2011, 05:07 PM   #2562
Yes, i know itīs the 10 Ohm in parallel. The 2 x 5 Ohm plus 50 Ohm just gives a bit less noise and more Gm but it is not very critical. In an open loop design much more then in the Rabbit Hole that works with strong feedback.
Old 20th August 2011, 03:06 AM   #2563
I found an interesting phono stage on the Tube Cad page. I post it hear just for completeness.
Old 21st August 2011, 12:08 AM   #2564
Some more stuffing has being doing on the Magnum Opus. I am nearly finished to fire it on for the first time.
Old 23rd August 2011, 01:47 AM   #2565
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Mpp
Joachim, what sort of price would the Magnum Opus be, theoretically speaking..
Paradise Pre-reg PSU PCBs
Old 23rd August 2011, 04:13 AM   #2566
You mean in the shop, in Japan for example, 30.000,-€. Itīs totally over the top. Making it is around 6500,.€. You can reduce cost a lot by using other resistors and caps and making a less elaborate PSU. The absolute minimum would be 2000,-€ material cost i assume without too many compromises.
Old 27th August 2011, 06:22 PM   #2567
Woooh...
That is expensive, I could manage the DIY priced option, 2000€ certainly isn't out of reach for a project that takes a few months. If you ever decide to make pcbs available, please let me know, even if I have sign a none disclosure agreement ;-)
Simon
www.bestkiteboarding.com
Old 27th August 2011, 06:46 PM   #2568
Hi Simon !
A lot of the cost is in the pre-regulator i posted. If you use a more conventional supply and use normal metal film resistors plus less expensive caps ( no Black Gates, Silmik2, Mundorf Silver-Gold-Oil ) and no metal can LME49710, OPA627 you can cut the cost down to maybe 500,-€. Also for the PCBs i used Isola G200 that is also expensive. I am planning a run of 10 FR4 PCBs that also will cut the cost down. When i get this PCBs i will post it on this forum. I could then supply the PCbs plus circuit diagram and construction hints. The transistors have to be selected so just stuffing the board does not work. It creates a DC offset that sets up the second stage so it is not easy to build it without instructions.
Old 27th August 2011, 06:55 PM   #2569
Having built the HP5.1 phonostage without any instructions I know how painful that can be. I'll keep my eyes peeled for the PCBs.
Old 27th August 2011, 07:02 PM   #2570
OK, fine. I will help as good as i can.
MppHide this!Advertise here!
Copyright ©1999-2017 diyAudio
