Mpp
Mpp
Old 3rd May 2011, 06:20 PM   #2221
reinhard is offline reinhard
Fully differentially is a network between the two phases.
Two networks to ground are not differentially.
Reinhard
Old 3rd May 2011, 06:23 PM   #2222
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Sure. My FPS is fully diffential though as far as i can tell.
Old 3rd May 2011, 07:00 PM   #2223
mzperx is offline mzperx  Hungary
Originally Posted by Joachim Gerhard View Post
How did you modify the Soundcard ?
OPA1612s are risponsible for the results. See the "before/after" details in excelsheet.
Does the Hagerman implement the Neumann "pole" and is this the reason for the rising response towards 20kHz ?
I don't know. May be I left a related jumpers in wrong position. Or 100R output impedance of souncard instead of expected 50R could couse it?
Old 3rd May 2011, 08:14 PM   #2224
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
have you ?
Pretty parts and construction, but as exciting as a Lexus.
Given the choice between 16 parallel parts or INA/AD797, i'd sooner pick a BB & AD Käfer Klirraudio (© Herr Löesch) balanced-ref for less than half the C27 cost.
Goes for all AccuPhase gear, long time ago i was rather impressed by the P102 balanced power amp till audit time. Deliberate market choice by the Yokohama brand, i assume, no thrills and no surprises.
(i loathe horns and anything fullrange high efficiency, had a ball at ETF , pretty S/N numbers for moving coil are not on the top of my list)
I do need a cell phone with prettier pixels.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 4th May 2011, 02:46 AM   #2225
Mzperx, you choose to not disclose your circuit, neather on the phono, nor on the soundcard modification. That´s fine for me but i can not comment any more detailed that way.
One channel of the Super Pocket Phono is working and the other channel is ready soon.
Old 4th May 2011, 02:53 AM   #2226
Here are some pictures.
Old 4th May 2011, 02:57 AM   #2227
Here is the circuit diagram and an alternative input section.
File Type: pdf SAM Cascode Pre-Pre FF2011 Transdiode.TSC - TINA.pdf (50.6 KB, 172 views)
Old 4th May 2011, 03:52 PM   #2228
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
What type of resistors are you using ?
I really like your hard core p2p builds
Old 4th May 2011, 04:02 PM   #2229
Thanks, they work very well. The resistors are sold under the Yageo brand but made as far as i know in Germany at Vitrohm. It is a 1% metal film. They are inexpensive but very good. I use them in prototypes and less expensive gear. Maybe i can find the specs.
Old 4th May 2011, 04:06 PM   #2230
here we go....
MppHide this!Advertise here!
