Mpp - Page 191 - diyAudio
Old 20th November 2010, 08:53 AM   #1901
Joachim Gerhard's Avatar
Guess what ? This crazy thing is playing ! It hums a bit. Most of it comming from the motor in my turntable. I was able to reduce that quite a bit by moving the stage further away from the turntable. I will try other things like shielding with Mu-Metal but i can say right away that tonal balance is not much off. I can not say for now how much wideband noise it has. The hum is too dominating so i have to work on that to find it out.
This is by far the most unlikely stgae i ever build and it is ultry simpel. Edgar, you are a funny chap and isnīt it the fun that drew me again into DIY ?
Old 20th November 2010, 09:10 AM   #1902
This is the current setup.
Old 20th November 2010, 09:18 AM   #1903
masag1 is offline masag1  Germany
Hi Joachim!
Really cool your design.
Do you need MU-Metal foil for shielding?
Sam
Old 20th November 2010, 10:19 AM   #1904
Yes, Sam, that may be necessary. The coils are rather big too. I could make some smaller ones but time is running and i have to prepare my lecture about my G-Pole speakers.
Old 20th November 2010, 10:23 AM   #1905
I forgot to post the screenshot of the 1kHz square. Here it is.
Old 20th November 2010, 10:38 AM   #1906
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Old 20th November 2010, 11:46 AM   #1907
I was able to get the hum down enough to do some serious listening. Putting an alumimum
plate over the coils helped a lot. I tried also to encase them in one of my infamous cookie boxes but that RAISED the amount of hum maybe because they are magnetic. I am sure a well made Mu-Metall coil from Sowter whould be dead quiet but again not really cheep.
Maybe i find a solution that works without costing a fortune. Besides the small hum the stage is dead quiet. I listened to a diet of Melody Gardot, Valery Carter and Sting ( Symphonicities ) and found the sound very balanced, kind of sweet and liquid and superbly low in disturbing noises. This is really easy listening but the stage was wide, high and deep too. I realy think this priciple is a valid alternative and provided the hum problem is solved i see no reason why a state of the art stage could not be made that way. It works of cause only when the Impedance of the cartridge is taken care for.
Old 20th November 2010, 11:59 AM   #1908
I can send a DIN A4 sheet of self adhesive MU-Metal Foil, If you want to try it.
VG
Sam
Old 20th November 2010, 12:52 PM   #1909
That whould be very good Sam ! I really apreciate that. I have only a little somewhere and can not find it when i need it.
Old 20th November 2010, 01:10 PM   #1910
VT67 is offline VT67  Belgium
VT67's Avatar
VG
Sam
Where can one order these sheets. I can use one to shield a measuring device.
Copyright Đ1999-2017 diyAudio
