Mpp - Page 172 - diyAudio
Old 17th August 2010, 02:35 AM   #1711
Joachim Gerhard's Avatar
Here is a picture of the buffer, with and without flash. I let it burn until tomorrow and then listen. I have two hours left so i will work on the +-17V Hypo. The picture shows the current state. 200 Ohm test resistors in the minus feed not installed yet. I have to go again through the sugestions.
Old 17th August 2010, 02:42 AM   #1712
No, i use some of the Leds in the signal chain for current feedback and low impedance steering. Sorry that i can not tell more. One of my friends said : 99% for me (DIY) and 1% for god.
Old 17th August 2010, 02:52 AM   #1713
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That's another use then. But if the LEDS are from same intensity batch and Vf matched, then it must be different currents. One or another. You got to be sure by installing new LEDS from sure batch first. But I have also seen a 1.75Vf LED surely dimmer than a 1.82Vf LED from same bag for 5mA for instance.
Old 17th August 2010, 03:03 AM   #1714
Good sugestion, i will measure the batch before i install. Anyway, the buffer is working and the Leds that do the dirty job are similiar if not ideal still. Idealy i whould need a Led
( or a string of two ) that drops 3.2V at 3.5mA so you see my dilemma. A blue one ? A mini string of IR ? Who knows.
Old 17th August 2010, 03:09 AM   #1715
I tryed two red ones in series that should give 3.6V and that is close enough but they where starving in the circuit and gave only 1.8V in total. I ordered a batch of red and green in high efficieny and normal. Not a big issue, i have time for this experiment and will find a solution as usual.
Old 17th August 2010, 03:11 AM   #1716
there are also low noise voltage references availlble that could do the job too.
Old 17th August 2010, 04:40 AM   #1717
setting the Hypo to +-17V without load was not a big deal. I got 17,3 and 17,4 volt fast and easy. Connecting the ULN phonostage the voltage dropped to 9.7V positive and 15,5V negative so it draws more current from the positive side. Offset management was still not upset and i measured the same values as before. That is a good experience because that offset had caused me lots of trouble in the beginning. I will make the rest of the adjustments next day. By the way one shunt mosfet gets now warmer then the other but that is logical. Slowly i get into it. It´s fun by the way.
Old 17th August 2010, 10:30 AM   #1718
Salas's Avatar
Give it a good margin of CCS:Load. 2:1 if it can take the heat I would recommend. Measure load current with 317/337 handy PSU in each circuit before you set Hypno's CCS for different CCTs. It will save time in resetting.
*Blue LEDS are noisy compared to Red etc. Best for noise are IR. Given that you got good makes and batches for best noise from each color.
Old 17th August 2010, 02:23 PM   #1719
I found an Osram SFH409 that drops slightly over 1V at 3.5mA, so a string of 3 could work. I found another IR Led that only needs 0.4 mW/sr @ 1.2V.
Old 17th August 2010, 05:13 PM   #1720
I have now made more listening tests with the OL buffer 4 prototype and now i understand what PMA is saying. As long as you have not heard something better the OPA134-BUF634 is just fine. Switching to buffer 4 reveils a much bigger and more populated stage. Dynamic slamm is much enhanced and the Opamp buffer sounds clean but also lifeless and sterile in comparison. The question that now arises is if that is a function of using heavy voltage feedback or rather not as Allen Wright is fiersly advocating. I have just drawn a schematic that combines an Opamp with buffer 4 to make it a high feedback voltage follower and then i will do the listening all over again.
Copyright ©1999-2017 diyAudio
