Old 7th April 2010, 12:13 PM   #1171
Ghianni is offline Ghianni  Greece
Default April 07
Phantastic photos by the way
Yes indeed! he used a x.xxx $ pro-camera...But the reason is that your gear is great.
Old 7th April 2010, 02:48 PM   #1172
Morfeus is offline Morfeus  Germany
Originally Posted by Joachim Gerhard View Post
I will come to the Frickelfest.
Great, Joachim!
I am following this thread from the beginning and I am very curious to hear your pre.
Looking forward to see you there.
Heinz
Old 11th April 2010, 11:32 PM   #1173
Joachim Gerhard's Avatar
I am working on the Balanced-In, Balanced-Out, Instrumentation, Inductive RIAA for several days now. It is quite a complex beast and much more delicate work than i thought. For my own use i am building a Low Z version because i simply like the slam and drahma circuits like that provide. The input stage of one channel is ready. I have not closed the feedback loop yet. I wait unil tomorrow and will chek everythig double.
I hate to see smoke or OPamps with red ears. I will post some photos later and will stop to build today. I need a rest.
P.S.: I am looking forward to see you Heinz. I hope to bring a complete DIY system.
What is still missing is a poweramp. I am collecting ideas. Maybe something single ended Cass A or let´s see what Brianco is getting together.
Old 11th April 2010, 11:52 PM   #1174
Here are some photos of the input stage. Sorry for the poor quality. My camera is not very good at night in the nearfield.
Old 12th April 2010, 12:07 AM   #1175
Audiofanatic's Avatar
Default Tube amp !
Hi Joachim,
It seems like a tube amp kind of circuit the way you put things together
I'm curious about the sound, I'm still busy rebuilding my home, otherwise I'd make a copy of your amp to try it out
I'm going to bed now, it's late again.
Audiofanatic (José)
Be nice to animals.
Old 12th April 2010, 12:16 AM   #1176
It´s a novel topology with advantages i hope. Needs only one coil for balanced.
I will publish the circuit when it works. To do this with tubes whould be imposible but i use this "dead bug" groudplane style all the time now. No problem with hum and easy to change and repair.
Somebody is now also working on PCB´s for some circuits i consider finished.
I hope they turn out well and make building easier.
Old 15th April 2010, 01:03 AM   #1177
I have now 130 Ohm and 300 Ohm resistors from Simon that measured well ( see Blowtorch thread) and i got 138 Ohm ( recommended by David Wilson for the Lyra Olypos
i have in house) and 300 Ohm naked Z Foils from Sigurt.
I am just building the latest version of the High Z MPP with transimpedance 75usec and capacitive RIAA to make the listening test. I will build that in a proper cabinet.
Dear Salas, i am still not finished with your Shunt but i have all parts now.
Old 15th April 2010, 10:15 PM   #1178
Default Resistor swapping
Today i did the first round of listening to loading resistors. I am using the latest version of the High Z MPP Transimpedance, Capacitive RIAA. The culmination of 1 year of hard work. It sounds just w........
Picture and circuit included. I use a current and voltage buffer to drive my 5m long cable to my high speed ( 25MHz -3dB) reference preamp. I use my MPL speakers.
The reference resistor is a Dale NS-2B 300 Ohm wirewound. That resistor sounds better then a 1kOhm TX2352 naked foil in my system but i will try a 300 Ohm naked foil tomorrow. So let the cat out of the sack as we say here. The resistor i listened to for comparison is a Dale Mil.Spec. RS65E i got from Simon.
i comfortably trampled the NS-2B. The soundfield with this resistor is much more populated in the midle and tonality is much more homogenious like listening to a full range speaker. There is no doubt any more what kind of instrument is playing. a Flugelhorn is a Flugelhorn and not a trumpet. Distortion is subjectively very low. I know that beacause i can play louder as usual without my right ear starts to distort. Distortion always starts in my right ear first. I think i have to go to the doctor to blow some dirt out. I did that ones and the gain in sound quality was amasing. Voices are magically 3 dimensionally delineated. This resistor is highly recommended and not so expensive. Ceveat : It is BIG. It has a 1/2 watt military rating but it looks more like a 2 watt.
File Type: jpg High Z MPP Transimpedance Capacitive.jpg (81.0 KB, 234 views)
File Type: pdf High Z MPP Fet DC offset fineadjust Capacitive RIAA.TSC .pdf (92.2 KB, 117 views)
Old 17th April 2010, 08:57 AM   #1179
bocka is offline bocka  Germany
Hi Gerhard,
I just took a look into the vishay datasheet. To me it seems this resistor (Vishay NS02B) is rated at 3 watts. I think this is the reason why it is such a big one. I've been gone for quite a long time here from diyaudio. Really a nice, straight forward design.
Old 17th April 2010, 11:58 AM   #1180
Thanks. Yes, in the commercial world this whould be a 2W or 3W resistor but Mil.Spec.
parts are rated more critical.
This resistor (RS65E) may be good for speakers too. 3W is just enough for a tweeter but we could parallel some for higher wattage.
By the way the NS02B is slightly smaller.
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
Horton, gk7, FdW
Page generated in 0.10830 seconds (66.56% PHP - 33.44% MySQL) with 10 queries
