MPP
MPP
Old 24th March 2010, 10:39 PM   #1121
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Lme49990
Joachim, here is another candidate for lowest noise & lowest THD: the LME49990.
THD < 0.00002 at 20kHz, PSRR > 100dB at 20kHz.
Blows your mind.
http://www.national.com/ds/LM/LME49990.pdf
jd
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 24th March 2010, 10:48 PM   #1122
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I have seen that. PSSR is amasing. When you think you have found a good OP amp another is showing up quite soon recently.
Athough National fired a lot of famous designers recently there seems to be an infinite number of substitutes on the free market.
Old 24th March 2010, 10:52 PM   #1123
Here is the circuit and some pictures of the Rbb setup and parts for the RIAA encoder.
File Type: pdf McCormick rbb` measurement set-up.TSC - TINA.pdf (53.7 KB, 91 views)
Old 24th March 2010, 11:01 PM   #1124
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Default Lme49990
Hi Joachim, Jan,
I'm gonna order a few LME49990 and make a nice little amp with them and will post my result when ready.
Thanks for the info!
Best regards,
Audiofanatic
Be nice to animals.
Old 24th March 2010, 11:07 PM   #1125
Thats fine. They come quicker then i can purchase them, not to mention build anything.
We could organise a shoutout at Jan. AD against National.
Anyway, the way i use the AD makes distotion so low ( shunt feedback) that audible differences will be very small. I have not studied the National enough if it can drive a feedback resistor lower then 600 Ohm. In that case, using the Phonoclone topology you have to burn a lt of amplification in a resistive devider.
Old 25th March 2010, 03:21 AM   #1126
Default RIAA encoder
This is the RIAA encoder i will make.
Design is by the trustable Burkhard Vogel.
I will select the parts as good as i can and will do some quarewave measurements to my latest designs.
File Type: pdf RIAA encoder Design Burkhard Vogel.TSC - TINA.pdf (53.2 KB, 161 views)
Old 25th March 2010, 03:24 AM   #1127
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
MPP
Is that from Sound Of Silence?
Old 25th March 2010, 05:18 AM   #1128
Yes
Old 25th March 2010, 05:32 AM   #1129
Salas's Avatar
MPP
You would need super exact capacitors and resistors so to have any tight tolerance curve check meaning. Tough without a lab grade calibrated bridge to select. It can simply compound with de-emphasis tolerances and even out or boost a curve trend erratically, If it does not have seriously better selected components than what it feeds. Maybe it will be practical to tune it against a text book Riaa emphasis curve graphically on the FFT than to be sure about parts values. Just an idea.
Old 25th March 2010, 06:40 AM   #1130
Usually i work with a mathematically generated curve in my DAAS analyser.
This is not awailable at the moment out of known resons.
I selected the parts by using 0.01% reference resistors and 0.1% reference caps.
My bridge shows values that are 99.9 kOhm for a 100kOhm resistor and 9.9nF for a 10nF cap. I interpolated the values and trimmed with 1% silver mica. That is the best i can do at home. Lets see what happens because the mathematics of the Self RIAA are indisputable.
I am planning on an aditinal balanced input for The JG Self.
The topolohy is an inamp made from Op amps.
I made the resistor values as low as i could to avoid noise. The LME49990 can drive 20mA clean so with the choosen values i get 3V max output. That is ample for a Pre-Pre.
Noise should be around 1.4nV / qHz
MPPHide this!Advertise here!
