MPP
MPP
Old 15th January 2018, 03:56 PM   #10931
avinunca is offline avinunca  Europe
MPP
Help sought - My Paradise shunt regs are using 40mA more on the positive rail than on the negative rail. I bought a completed Paradise phono minus prereg as a stop gap until I could build my own.
So with +/- 26V I see 145mA on negative rail and 185 mA on positive. The Calvin buffer is disconnected. I can adjust for 18V on both outputs. Pics of one board here
Michael Lakeman | Flickr The amp works and sounds good to me. Maybe it could sound better though.
Old 15th January 2018, 04:08 PM   #10932
hesener is offline hesener  Germany
MPP
Check the 10 Ohm resistors (R104, R204) for their values. While not ideal, this difference is not alarming. Is it the same behaviour on both channels? And, do you have a scope where you can check if one of the regulators is oscillating?
If that doesnt work , the regulator schematic has typical voltage levels noted, you may want to check those.
By the way, there is a paradise builders thread here: Paradise Builders
where you may want to ask those questions, maybe better than in this MPP thread....
Paradise documents are here: Link list
Old 15th January 2018, 04:13 PM   #10933
MPP
Thanks Hesener. Sorry I posted in wrong thread. It's same both channels. Will check resistors and for oscillation.
Michael
Old 15th January 2018, 10:07 PM   #10934
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Originally Posted by Joachim Gerhard View Post
I can say one thing : there is no superiour topology. It is all in the details and execusion.
And that comes from a man who has build any thinkable topo, at least quite a lot! If you think about it, it would be very strange if there were such thing as a single best topology.
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 15th January 2018, 10:12 PM   #10935
Onvinyl's Avatar
Originally Posted by RCruz View Post
I like the Pearl phono.... very good design.... maybe it could be improved with a good psu.
I am sure the psu is an integral part of any amp because it sings along with it.
I use a pair of jfets in the input of my phonostage... and it is quiet.
Hi RC,
Which circuit are you using? I often experienced (well, three different topos or so...), that a single fet sounds better than paralleld fets if it werent for the noise penalty.
Rüdiger
Old 15th January 2018, 10:23 PM   #10936
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
So the most simple circuit that does the job is the best. Theoretical. Occam´s Razor.
Anyway, with vinyl it is also about taste in sound so reaching the goal in a particular system is not that easy any more. Is is about beautiness in sound ? Then it get´s real difficult. So what is the job ?
Old 20th May 2018, 10:49 AM   #10937
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Hello Joachim
Still trying to understand the paradise schematic and need your input.
There are two voltage references that provide VCASCH and VCASCL.
The are made with a ccs and a zener in each case.
R11 Q97 D2 and R10 Q98 D1
What is the purpose of such a circuit ? In my simulations the circuit works perfectly without these subcircuits......
BTW.... Good sound in the MOC this year.... love your speakers
Ricardo
File Type: jpg Paradise%20R3%20schematic%20amplifier_notes.jpg (534.4 KB, 161 views)
RC
Old 20th May 2018, 10:51 AM   #10938
nhinstruments
RCruz's Avatar
MPP
better sch
File Type: pdf Paradise R3 schematic amplifier annotated (1).pdf (21.3 KB, 55 views)
RC
Old 20th May 2018, 05:06 PM   #10939
Calvin is offline Calvin  Germany
Calvin's Avatar
I guess D1 and D2 are just used to drop voltage so that the JFETs don't suffer from high Vds and heat losses.
jauu
Calvin
Old 20th May 2018, 06:33 PM   #10940
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 MPP
They do nothing. They are a hangover from a previous incarnation of the circuit and they were just never removed from the schematic as the circuit was improved. (I think one of the team secretly had shares in 2sk170s ;-)
Paradise Pre-reg PSU PCBs
MPPHide this!Advertise here!
