MPP
MPP
Old 13th March 2010, 12:30 AM   #1021
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Default Joachim
Hi Allen,
Joachim and I have more or less the same illness.
We just don't know when to stop and actually if it wasn't for our partners, we would stay awake the whole day just for audio purposes.
Joachim, don't listen to Allen, listen to me GO TO BED
Tjuus,
Audiofanatic
Be nice to animals.
Old 13th March 2010, 06:24 PM   #1022
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I slept well, thank you very much.
I put more thought into the BJT INA.
The current sourced caskode did not work so well with BJT´s so i simplified a bit.
They are now fed by a capacitance multiplier and the feedback goes directly from the collectors.
Circuits like that proved to work in designs by Douglas Self and Burkhard Vogel but they used them unbalanced.
Idle current in my design is adjutable for minimum DC offset and optimisation for an MC with higher impedance like the Denons and Clearaudios.
When i use 4 x 4 input transistors and reduce the feedback resistor to 1 Ohm i could get 0.3nV/qHz in a balanced design.
Old 14th March 2010, 01:25 AM   #1023
i promissed some photos.
I have build a lot of stuff where i only posted the schematic.
I changed now from building in the small metall boxes to groudplane construction.
I use a double sided board so in a double mono construction i have 4 groundplanes and i use a metal box under that for a 5th groundplane. I place connections of the groundplanes at strategic positions. I also earth the planes at one point with a 6.8uF cap to wall outlet earth.
I have a cable with two wires from the tonearm and one shield that is connected together at the tonearm side. That way i can try balanced and unbalanced.
File Type: jpg Balanced In - Unbalanced Out Buffer.jpg (108.1 KB, 379 views)
Old 14th March 2010, 01:28 AM   #1024
Here is some more
Old 14th March 2010, 01:32 AM   #1025
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
MPP
Dead bug P2P = hardcore DIY. I like!
Old 14th March 2010, 01:35 AM   #1026
Salas's Avatar
MPP
P.S. Batteries...I don't like! Where are dead bug inferno hot Mosfets on wildly oscillating shunts?
Old 14th March 2010, 01:35 AM   #1027
It performs great and can easily being changed.
Look at the third picture on the right, last post. Left is the FET INA and right is the BJT INA.
Old 14th March 2010, 01:38 AM   #1028
Salas's Avatar
MPP
Very good. But can you write a service manual?
Old 14th March 2010, 01:40 AM   #1029
i started to build the Shunts. The cabinets arived and i bought BHC Slit Foil caps instead of Sikorel. I worked a lot with Dennis Morcroft of DNM. the invertor and always wanted to try them. Mosfet are also on the way and i build most of the small parts.
Old 14th March 2010, 01:41 AM   #1030
Salas's Avatar
MPP
I see 1837s and Polystyrenes here and there. I will try COG-NPO for RIAA filter caps soon. Did you ever try any? Nice tiny for dead bug.
MPPHide this!Advertise here!
