MPP
MPP
Old 31st August 2014, 01:30 PM   #10171
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I found this in another place but it looks the same.
I think the schematic works.
My phono had also the input buffers that where coupled over the sources.
This circuit is quite fast because it minimises the effect of input capacitance.
The input is a buffer and the parallel symmetric differential stage that follows works in common gate mode so the signal goes into the sources.
Old 31st August 2014, 03:32 PM   #10172
FdW is online now FdW  Netherlands
FdW's Avatar
MPP
The lab has now it's own amplifier (a little GainClone) for testing, so I do not have to risk my main power Amplifier when testing
Old 31st August 2014, 04:11 PM   #10173
Is the circuit conventional or did you do your magic wand ?
Old 31st August 2014, 04:19 PM   #10174
FdW's Avatar
MPP
Nothing special, just as in the datasheet
Old 1st September 2014, 07:23 PM   #10175
We had some success here with bootstrapping discrete buffers and even made a linestage.
For another project over at the Frickelfest Forum i needed an Opamp buffer.
The goal was using components that everyone has lying around, maybe even since the 70th.
So i chose the NE5532. Conventional buffer and then inverted gain stage with Class A bias plus a discrete Diamond Buffer.
This is a Headphone Amp that drives low impedance but it can also be used as a line stage.
The sound i got in my system was a surprise.
I think i can not make the gain stage any better given the limitations of very low budget but i think i can improve the buffer.
It is AC coupled out of several reasons so bootstrapping the input resistors is possible.
Here is the schematic of the Headamp called The Caveman and the bootstrap idea.
For the resistors i thought 47kOhm is fine.
Then C2 can be 2.2uF for example.
C1 can then be really small.
File Type: png Ac Coupled bootstrapped Opamp Buffer.png (81.2 KB, 308 views)
Old 2nd September 2014, 03:55 PM   #10176
Just for completeness i found this older Electrocompaniet MC Pre-Pre circuit.
Considering the age i find it rather clever.
File Type: png electrocompaniet_pre-pre_phono_mc-2.pdf_1.png (62.6 KB, 193 views)
Old 7th September 2014, 10:09 PM   #10177
List of dynamic range :Album list - Dynamic Range Database
Old 8th September 2014, 09:54 AM   #10178
FdW's Avatar
MPP
And I think it's ugly
Old 8th September 2014, 09:56 AM   #10179
FdW's Avatar
MPP
That's a cool list
Old 8th September 2014, 12:24 PM   #10180
There are interesting elements in the circuit so i posted it.
Electrocompaniet made many things different in the old times.
I watch it out of historical reasons.
MPPHide this!Advertise here!
