| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I was thinking about making a turntable isolation shelf. I was wondering if anyone has made one and how successful it was.
Thanks Steve |
#2 |
My system sits on a homemade rack, similar in design to Hi-Fi racks Trio, or the Atacama equinox, made from solid oak.
The shelves however are 'Tesco finest granite worktop savers' similar items available in Wilkinsons (uk for about 9gbp each, 400mm x 300m x 15mm). These shelves are isolated from the rack by sitting on squash balls, a few pounds from any sports shop. For just over 10 pounds you have a isolation shelf that rivals the ones on ebay costing in excess of 10 times as much. A dedicated wall mounted shelf would help substantially. Squash balls and granite shelf to further decouple and isolate any unwanted vibrations. |
#3 |
I built a wall mounted sand box with @ 75 Lbs of sand and a granite tile. Worked great. I had zero issues with vibration after I built it. You could wrap on the oak box with your knuckles and barely hear it even with the volume up pretty high.
#4 |
Go for a granite shelf as done in DPS. It is designed by Frank Schroeder.
#5 |
When my DIY Turntable is finally complete a sandbox/granite/oak platform will be made. Similar in design to TNT sandblaster.
The TNT SandBlaster 1.0 |
#6 |
Thanks that's what's great about this forum. All of your ideas got me looking around a little and I found this article. you might find it interesting also
Galibier Design - Frequently Asked Questions |
#7 |
#8 |
Something I don't quite under stand about the sandbox platforms. Does the top sit directly on the sand with out any other support? If it does how do you get it perfectly level?
#9 |
Typically there is a shelf that "floats" on the sand. The sand is covered with a plastic film to keep it from getting all over. There is a bit of fiddling to get the shelf/platform to be level. Level also needs to be checked periodically since the sand may shift/compress further.
I was so much older then, I'm younger than that now. |
#10 |
I built the shroeder/makris design on the galibier page.
I built the sandbox out of 1/4" aluminum as that is what I had about. I still can get a feedback low frequency woofer excursion @ higher volumes but if I keep it under 105db I'm fine. With the needle in the groove, measuring the voltage output at the phono stage while doing the rap test on the stand I get less than 20mv output. Regards,Bill |
| Cheap, Fast, Turntable Isolation: Sorbothane and the Enco Surface Plate | DaveThreshold | Analogue Source | 5 | 21st April 2007 04:07 AM |
| 'off the shelf' FE87E BLH | bibster | Full Range | 3 | 16th June 2006 08:06 AM |
| shelf/mounting a TT | dieselpower | Analogue Source | 2 | 25th January 2005 08:23 AM |
| And what about those shelf systems? | r_s_dhar | Everything Else | 2 | 1st December 2003 11:18 PM |
| Page generated in 0.08666 seconds (87.67% PHP - 12.33% MySQL) with 10 queries |
