no bass
no bass
Old 11th October 2009, 10:20 PM   #1
mor2bz is offline mor2bz  United States
Default no bass
Thanks anybody in advance:
i am getting far less bass with my tt setup than with cd. i have the MMF with
the topend goldring cartridge, a wright wpl11 phono amp, a bedini 125 amp, and dynaco a35 speakers.
i know the speakers have a rising response, so that is part of it.
i do not want to put the speakers any closer to the walls; then the cds will sound too bass-heavy.
any ideas? thanks again
Old 11th October 2009, 11:24 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
no bass
Try a different phono/pre amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 12th October 2009, 01:21 AM   #3
Jeffrey Davison is offline Jeffrey Davison  United States
Play around a bit (if you can) with your VTA..(vertical tracking angle)..
JD
Old 19th October 2009, 03:10 AM   #4
kyrie48 is offline kyrie48  United States
It's called "HiFi"... but seriously, part of it may in fact be; more realistic/flat response from a time when such things mattered.
Did you check the wires where they connect to the cartridge??
Old 19th October 2009, 03:47 AM   #5
Nanook is offline Nanook  Canada
Nanook's Avatar
Default if the bass is heavy, are the highs gone too?
if the highs are MIA, then lower the arm and adjust until the soundstage opens up and treble is apparent.
Do a search, lots of info out there. Also check your VTF accurately. Again, lots of info out there.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 19th October 2009, 04:15 AM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
no bass
Could it be due to your vinyl is of older date and your CDs are new
Maybe your new Cds have more bass than your older vinyl
Further, your phono may have a cap on output
Being a tube phono this cap may be sized to suit a tube amp, which usually have high input impedance
Your Bedini is I guess a SS pre, and will have much lower input impedance, which means the output cap of your phono may need to be bigger, or it may roll of bass
I no expert, so others should comment on this
Old 19th October 2009, 04:27 AM   #7
another thing to consider... different recordings through time may have slightly different RIAA equaliztion. There is a standard, but some labels held them loosley and "interperetd" them for their own needs.
If you go to this link, check out all the info and also look at the bottom of the page where you can see how the EQ was applied by the recording labels.
http://www.soundfountain.com/amb/ttcartridge.html
JD
Old 19th October 2009, 05:44 AM   #8
Borat is offline Borat  United States
Banned
i know nothing about vinyl but what little i do know is that bass is a rather fundamental limitation with this technology. at the same time digital audio has NO limits when it comes to bass.
i have no doubts you will find a way to improve your bass performance with vinyl but ultimately if you are a bass head i think you are headed in the wrong direction.
tubes also have issues with bass. maybe thats why vinyl and tubes go well together.
really i know nothing about vinyl but i know ALOT about bass and virtually everything about bass is better done digitally.
Old 19th October 2009, 06:33 AM   #9
chris661 is offline chris661  United Kingdom
chris661's Avatar
If the pre-amp is of any age, the output caps (control rumble filtering etc) may have dried up, leading to the bass being rolled off higher up, as the cap rating would have changed.
Might be an idea to open it up and do some measurements. If you could test with another pre-amp, this would help a lot.
Chris
My work: www.grimshawaudio.com
Old 19th October 2009, 06:33 AM   #10
PLB is offline PLB  United Kingdom
Hi Mor2bz
About the only thing I could recommend is to buy yourself a vinyl test record like this one on eBay.
New Sealed The Ultimate Analogue Test Vinyl Record - eBay (item 260483730813 end time Oct-28-09 15:38:17 PDT)
With this you could test your whole system.
Peter
no bassHide this!Advertise here!
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 07:42 AM
WE 350: dry bass? wildbox Tubes / Valves 2 22nd February 2008 06:38 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Copyright ©1999-2017 diyAudio
