diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   HELP ZETA-ARM bearing (http://www.diyaudio.com/forums/analogue-source/153135-help-zeta-arm-bearing.html)
GIPIONE 9th October 2009 05:59 AM
Same of you have change the bearing of e zeta-arm??
Its movement is perfect ti up-down but the movement lateral isnít easy, sweet and I think necessary to change the bearing
Here are 3 bearing in the up, and the same number in support point underneath, and this is very difficult ( o impossible ??) to open this. The up cylinder-screw where there is the 3 bearing is easy to open and change, bat the under, that think of same typos, I donít know how use??
Now I have buy ceramic bearing for substitute ( 1/10Ē ) and I hope to make and obrtain a good work.
Help same of you have already do it??
Thank and best regards.
G.pietro
Italy-Treviso
:confused:
Curly Woods 9th October 2009 05:41 PM
Contact Mike Harris of the Moth Group in England. he should be able to assist you with your Zeta issues.
http://www.britishaudio.co.uk/aboutus.htm
hifidaddy 13th October 2009 08:48 AM
http://www.Audioorigamo.com (he is even present here in the forum) is doing repairs on the Zeta, as well as two tonearm specialist in Germany.
Years ago, I did such myself, but I have no longer time to repair stuff from others.
best regards, Hartmut
Curly Woods 13th October 2009 11:26 AM
Originally Posted by hifidaddy (http://www.diyaudio.com/forums/showthread.php?p=1948735#post1948735)
Hartmut,
The link appears to be bad. :)
GIPIONE 14th October 2009 10:40 AM
Thank for the answer, and pardon for later of my.
Now I hope to repair myself the arm; mrs. Harris I know form same years and think contact immediately .
New thank
G.pietro
TREVISO-ITALY
Curly Woods 14th October 2009 11:33 AM
You are most welcome :D Best of luck with your Zeta. It has always been a favorite of mine!
offanonone 15th October 2009 11:20 AM
Try this link for Audio Origami
Audio Origami - Everything from custom-made Tone Arms, Arm Rewires, Turntable set-ups, Custom Speaker parts and High Quality Cables, Terminals and Special extra slippery Bearing Oils and Pure Damper Oils.
John.
Copyright ©1999-2017 diyAudio
