Build your own tonearm cable - Page 3 - diyAudio
Old 24th November 2009, 07:50 AM   #21
binspaul's Avatar
Send a message via Skype™ to binspaul
Exclamation What is the required pin diameter for a phono cable cartridge clip ?
Any DIY clips project available ?
Best regards,
Bins.
Old 24th November 2009, 08:14 AM   #22
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Best regards,
Bins.
boyz at Vinyl Engine gave one good tip - find any D-sub (female ) connector - 9 or 25 oin , dismantle it , and you'll have plenty of cartridge clips .
tip: old printer or mouse or serial port ...... I can't even remember which one is female
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th November 2009, 11:16 AM   #23
binspaul's Avatar
Hi Zen,
Is that of the standard size ? Will that match all the carts ?
Best regards,
Bins.
Old 24th November 2009, 11:31 AM   #24
Zen Mod's Avatar
Hi Zen,
Best regards,
Bins.
yup
pic from VE
I tried - works like a charm
Old 24th November 2009, 01:09 PM   #25
Originally Posted by Zen Mod View Post
cotton insulated litz wire - scavenged from old RF coils
just find any broken ( even functional is good enough ) Boombox with MW , and pull that coil from ferrite rod
have an ample supply of "litz" 4-34 and 4-36 magnet wire that I'll gladly send a bunch to someone if they want to try it. (technically i think it is just twisted and not a true litz)
I also have to bonded triple #31 which one wire could be removed from to do two discrete runs.
these are just insulated magnet wires and do not have any cotton serving.
dave
Old 24th November 2009, 01:22 PM   #26
Zen Mod's Avatar
Dave , just wanna say that I had recently pleasure to make one nice attenuator ( for one member of our local forum ), based on pair of your AVC ;
dunno is there another pair in Serbia
that was really a pleasure , both in wiring and listening later .
Old 24th November 2009, 11:19 PM   #27
binspaul's Avatar
Some nice cable clips are available from HARWIN. But, I am not sure on the size that needs to be used for a phono cartridge. So, What is the internal diameter required for a cartridge clip ?
Best regards,
Bins.
Old 25th November 2009, 02:37 AM   #28
Be forewarned - soldering 36ga stranded wire will drive you to the looney bin. I just finished a set of tonearm wires that went straight from cart clips to ICs to RCA connectors. 7 strand silver plated copper wire totaling 36ga. Teflon insulation. The teflon's melting point was beyond the solder temp, so I couldn't allow the solder to burn it off. Stripping it with fingernails just damaged and broke the strands. Ended up carefully and VERY lightly scoring the insulation with a very sharp razor blade, then gripping the end with fine grit sandpaper between my fingers. That worked well - those times when I didn't slice into the wires with the razor blade.
When I did get to solder, sometimes the temp of the solder melted the wire.
I don't ever want to work with that stuff again. Ugh.
Old 25th November 2009, 11:27 AM   #29
binspaul's Avatar
Default D-sub pins are directly available...
Hi Zen,
I searched a lot on the D-sub (female ) connectors. Found some really promising info on that. The pins are directly available for purchase: CINCH
Is that the one that is really needed ? Please suggest...
Best regards,
Bins.
Old 25th November 2009, 11:34 AM   #30
Zen Mod's Avatar
Hi Zen,
Best regards,
Bins.
maybe is faster to find any old cable with this ( or 25 ) ;
in 25 ones you'll find several unused pins ...... with unused - I mean clean , not soldered .
they all have gold plating
Build your own tonearm headshell binspaul Analogue Source 27 5th February 2010 08:02 AM
Diagnosing a faulty tonearm cable bulgin Analogue Source 3 22nd September 2009 08:49 PM
Pinout of tonearm cable busoni Analogue Source 0 18th August 2008 09:25 AM
Soldering a tonearm cable - grounds 355F1 Analogue Source 2 9th March 2008 06:18 PM
Re-wiring a tonearm with headphone cable. mattjk Headphone Systems 1 2nd March 2005 12:40 PM
Copyright 1999-2017 diyAudio
