Build your own tonearm cable Build your own tonearm cable - Page 2 - diyAudio
Old 15th October 2009, 12:10 AM   #11
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
Originally Posted by moray james View Post
Mouse cable (fron a wired computer mouse)
Concur - cheap (usually free) light, colour coded, flexible and well capable of carrying the infintisimal voltages and current generated. I twist in two pairs - braiding all four (or five if you include an earth line) can lead to high levels of torsional stiffness - the braided cable doesn't flex as well and can affect tone-arm movement.
Cheers!
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 15th October 2009, 07:08 AM   #12
coolmaster is offline coolmaster
I'm having nice results with "cost next to nothing" mouse cable. I twist 2 seperate pairs and thread it through the arm and down the column with inches extra and free play there at the bottom. I also use those cartridge plugs from pulled from printer port. At the other end with extra few inches its terminated with another 4 terminal plug/socket also pulled from defunct PC audio card to a small DIY PCB which I then solder permanently a twin coax cable with female RCA connectors. I can then use normal interconnects to the amp. All this is quite cost saving, practical and easy to dismantle for any tweaks to the arm I can think of doing later on. Initially I thought these wires may be too thick but so far so good. Yes, I reckon many purists won't endorse or agree with this implementation, but what the heck, costs next to nothing and it works.
Old 15th October 2009, 07:42 AM   #13
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
cotton insulated litz wire - scavenged from old RF coils
just find any broken ( even functional is good enough ) Boombox with MW , and pull that coil from ferrite rod
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th October 2009, 07:59 AM   #14
slowmotion is offline slowmotion  Norway
slowmotion's Avatar
I used to use VdH silver in the tone arms.
Now I only use mouse cable.
It's much easier to work with,
lasts longer, sounds good and is practically free.
Cartridge clips is from a computer D-plug.
The VdH cable is sold.
Old 15th October 2009, 08:25 AM   #15
Those AM/MW antenna rods?.. did hear of these were useful here.
Old 15th October 2009, 11:26 AM   #16
offanonone is offline offanonone  United Kingdom
Best free arm wire i have used. Don't try to strip the wire !!
Use the tip of hot soldering iron to burn a few mm of cotton/silk insulation off. Tin the end and attach pins from a computer D plug.
John.
Old 15th October 2009, 12:02 PM   #17
Zen Mod's Avatar
John.
not just "best free" .....
it's better than at least half of fancy shmanzy ones
Old 15th October 2009, 09:53 PM   #18
Geek is offline Geek
Geek's Avatar
Brilliant!
You're good at more things other than PASSing the Pumpkins at THANKSgiving
*hears groans*
Cheers!
Old 15th October 2009, 10:05 PM   #19
Zen Mod's Avatar
ya nuckin' futz !
Old 15th October 2009, 10:12 PM   #20
Geek's Avatar
We try
Build your own tonearm cableHide this!Advertise here!
Build your own tonearm headshell binspaul Analogue Source 27 5th February 2010 08:02 AM
Diagnosing a faulty tonearm cable bulgin Analogue Source 3 22nd September 2009 08:49 PM
Pinout of tonearm cable busoni Analogue Source 0 18th August 2008 09:25 AM
Soldering a tonearm cable - grounds 355F1 Analogue Source 2 9th March 2008 06:18 PM
Re-wiring a tonearm with headphone cable. mattjk Headphone Systems 1 2nd March 2005 12:40 PM
Copyright ©1999-2017 diyAudio
