| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 | |
Laminations (from the latin 'lamina', a thin sheet). The laminations need to be electrically insulated - by coating with a layer of varnish sometimes - to minimise the circulation of eddy currents induced by the magnetic fields. Eddy current would waste energy and degrade the field. Ferrite is an electrical insulator, so does not need to be laminated, and can be cast in a single solid form. I think VCR heads are made of similar such stuff (harder than basic ferrite), for their high frequency magnetic characteristics. I'm not up on imperial head gap numbers! Typically, playback gaps are around 1 micron (um) and record around 4um. As mentioned my Kevinkr, transformer steel (the easiest to get) may prove mechanically too soft to be durable. Are Ampex heads made in 1950 likely to be more exotic material-wise than was available to Studer for their Revox heads? I have a few of the cylindrical Revox heads (worn out), and while the potting may be cosmetically 'ugly' I don't think that has any detrimental effect of the performance.
Steerpike's Toybox |
#12 |
Thanks Kevinkr and Steerpike, you've provided good input. I guess I wasn't aware of all those considerations. You obviously know things I don't!
Luckily for me I already have some 9 track tape heads from old Kennedy computer mainframe tape drives, and I will be using them. If I have time and ressources I will commit to building a head. Until then I think I shall reconsider!
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig |
#13 |
| Demagnetizing tape heads | DragonMaster | Analogue Source | 40 | 14th June 2011 01:04 PM |
| Source for Bogen tape recorder heads? | jacques54 | Analogue Source | 1 | 22nd April 2008 05:52 AM |
| Alps TAPE!! heads | DragonMaster | Analogue Source | 2 | 16th August 2007 01:50 PM |
| De-magnetizing tape heads | Sir Trefor | Analogue Source | 13 | 20th June 2005 02:29 AM |
| About tube tape recorder heads | walk | Tubes / Valves | 10 | 28th September 2002 09:22 PM |
| Page generated in 0.08935 seconds (75.18% PHP - 24.82% MySQL) with 10 queries |
