Old 24th September 2009, 12:55 AM   #11
Originally Posted by Nanook View Post
as the title of my response states, where'd ya get those specs?
the Vinyl Engine states:
Empire arm: 228.6mm, 17.3mm O/H, 23.8 ° O/S, 211.3 pivot to spindle
Kenwood KD550 arm: 237mm, 15 mm, unstated, 222mm pivot to spindle
looks like 10mm is needed to elongate the slots and to allow for a "twist", as per Dave.
Thank you!
Old 24th September 2009, 12:57 AM   #12
Originally Posted by directdriver View Post
Sorry, I simply lifted the numbers from the postings in Audiocircle: http://www.audiocircle.com/index.php?topic=70898.0
It turns out the overhang number for the Empire is theoretical, not the published spec, and the discrepancy is 1mm. I believe if you use a protractor and have enough slop room on either headshell or mounting area, you will arrive at a satisfactory point.
Sorry for adding confusion. Regardless of specs, what Big_Bill has is a great turntable (I used to own many Empire tables) with a seemingly well constructed tonearm and with a little tweaking and adjustment he will have great result.
Thank you!
Old 24th September 2009, 01:06 AM   #13
Default Reference point ??
I now understand why we are shifting the cartridge to the rear by 10 mm.
My question now is from what reference point do I measure said 10 mm?
Old 24th September 2009, 02:52 AM   #14
directdriver's Avatar
Your spindle to pivot is a fixed distance, assuming it's 211mm, then your overhang will be 17mm. 211 + 17 = 228mm. Make sense? Make sure you have some kind of protractor or alignment tool to do this.
Old 24th September 2009, 03:16 AM   #15
Where might a man like myself procure one of these fancy audiophile tools?
P.S. Is there a certain model which is better suited to dummies like me?
Old 24th September 2009, 04:51 AM   #16
Nanook is offline Nanook  Canada
Nanook's Avatar
Default elongating headshell slots...
seems like a good way to go, as per usual P10. But I'd use a new headshell, just to keep the original arm/headshell intact.
stew -"watch out where the Huskies go and don't you eat that yellow snow"--Nanook died of starvation 8 mos after the movie was made
Old 24th September 2009, 05:26 AM   #17
I agree!
I'm thinking of using the stock one from my old Pioneer PL-630 to customize.
P.S. Does anyone have a cartridge alignment tool they are willing to part with?
Old 2nd October 2009, 03:25 AM   #18
Originally Posted by Big_Bill View Post
I agree!
Well I now have a protractor and have set up the table using the stevenson math and it sounds great! I was able to slide the cartridge far enough back under the head shell to make it work.
Thanks again for everyones help!
Bill.
Cartridge for Scheu Tonearm kilowattski Analogue Source 1 28th December 2008 07:59 PM
Cartridge and Tonearm suggestions. Dougie085 Analogue Source 3 27th March 2008 04:58 AM
step up -cartridge match hal1 Analogue Source 1 1st October 2007 12:39 PM
Weathers tonearm, cartridge and W-21A oscillator eleakist Analogue Source 1 16th August 2006 03:25 PM
Some Cartridge and tonearm input please mashaffer Analogue Source 19 10th June 2005 09:45 AM
Page generated in 0.10303 seconds (75.06% PHP - 24.94% MySQL) with 11 queries
