Old 20th September 2009, 10:46 AM   #1
bocijo is offline bocijo  Romania
Default Phono preamp with NJM2068DD
Hello. I'm trying to build my own phono preamplifier, and i found some schemes over the net. I'm interested in this one, but i have a question about the grounding solution adopted in the circuit. I posted two images with the scheme and the power supply (the bridge part). I'm working on the PCB now, and i will posted when i'm finished designing it .. until then i'm waiting for opinions about the scheme. cheers.
P.s. I was also thinking of replacing njm2068d with tl 071. What do you think ?
Old 20th September 2009, 11:30 AM   #2
danzup is offline danzup  Romania
danzup's Avatar
Both capacitors in pics are for grounding of the case (enclosure) and the first one is connected to the ground terminal of 230V c.a. sector .
TL071 have bigger slew rate and lower noise than njm so it is ok .
Old 20th September 2009, 02:23 PM   #3
thanks a lot i suppose it's something like a loop circuit breaker .. http://sound.westhost.com/earthing.htm
also what does the LC combination on the stage input does ?? i think it's a low pass filter, but for what ?
Old 20th September 2009, 08:54 PM   #4
mjf is offline mjf  Austria
also what does the LC combination on the stage input does ?? i think it's a low pass filter, but for what ?[/QUOTE]
hello.
this should be a filter for radio frequency.
greetings.........
Phono stage with NJM2068DD or TL071/072 bocijo Analog Line Level 1 27th May 2010 02:37 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 04:17 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 08:32 AM
Phono PreAmp JTT Analogue Source 20 15th September 2004 05:24 PM
Page generated in 0.09119 seconds (76.25% PHP - 23.75% MySQL) with 11 queries
