Old 26th September 2009, 07:53 PM   #21
carolus is offline carolus  Belgium
Default titanium headshell
hi bulgin,
You love "exotique" materials, I respect your high tech lux concept.
FYI,
I used only "ordinary" (dur) Alu tube dia 10mm and with a inside inner bar (dur) Alu dia 8mm (non magnetic).
For the alu bar 8mm; with a fine file (zoete vijl) bring it "perfect" on 1/2 dia (for a old mech ingineer with ordinary tools no problem ).
I use (2) brassing (Cu) screws (non magnetic).
Allez, salukes en vriendelijke groeten,
Karel
Old 6th October 2009, 11:18 AM   #22
binspaul's Avatar
Send a message via Skype™ to binspaul
I am planning to use Aluminium for making this. The dimensions will be as suggested by Stew. But, I have few more questions:
1. What should be the size of the mounting screw used to join the plate to the tonearm ?
Best regards,
Bins.
Old 7th October 2009, 12:16 PM   #23
kffern is offline kffern  Australia
Send a message via Skype™ to kffern
This seems really simple and effective.
It's a unipivot by Consonance.
http://www.opera-consonance.com/prod...T988_T1288.htm
kffern
Old 7th October 2009, 01:39 PM   #24
kffern
WOW! That is such a simple design and very usable across different types of turntables.
It has me thinking about trying to adopt this type of headshell for older Dual turntables because a new Dual headshell costs about $30-$40 and I just can't see spending that much $$$ to have multiple cartridges to change in and out on my Dual 510.
The Consonace arm looks pretty nice and I wonder why there isn't any USA distributors? But I do see Grant Fidelity (Canada) has this available on their online catalog. Pre-order the LP6.1 for only $940 - doesn't look like a bad deal for a very decent TT.
Old 27th October 2009, 10:57 AM   #25
binspaul's Avatar
What is the cartridge mounting screw hole diameter required ?
Best regards,
Bins.
Old 29th October 2009, 10:22 AM   #26
binspaul's Avatar
Stew, any idea on the screw diameter ?
Old 29th October 2009, 03:09 PM   #27
Dedicated Audio - Dedicated Audio Non-Magnetic Cartridge Mounting Bolt Kit
Old 5th February 2010, 08:02 AM   #28
binspaul's Avatar
Hi Stew,
I made a tonearm head shell out of the solid aluminium using your diagram as the starting point. I made some modifications to the original diagram so that it looks much similar to the one designed by Frank Schroeder.
Thanks & Regards,
Bins.
Technics Headshell Socket/Tonearm Rewire KP11520 Analogue Source 2 24th March 2008 07:14 PM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 10:49 PM
seeking ideas for diy headshell (tonearm pics inside) percy Analogue Source 28 16th September 2006 10:40 AM
New Headshell -- too light GhettoSQ Analogue Source 3 28th July 2006 09:57 PM
Page generated in 0.08618 seconds (85.84% PHP - 14.16% MySQL) with 11 queries
