diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Mission 774 tonearm (http://www.diyaudio.com/forums/analogue-source/151634-mission-774-tonearm.html)
peter hawthorne 14th September 2009 05:09 PM
Mission 774 tonearm
Hi I would be grateful if any members would be able to let me know what the specifications of the bolts are that fit the cartridge to the mission 774 tonearm head shell or where I could purhase some. Thank you to any members who can help me.
Regards Peter.
Panicos K 15th September 2009 09:15 PM
Usually 2.5mm or 2.6mm
peter hawthorne 16th September 2009 06:07 AM
Mission 774
Thank you for your reply, would you know what type of thread is used. I have tried metric bolts and they will not screw in, Some one did mention that they could be one of the american threads. regards Peter
Panicos K 17th September 2009 11:57 AM
If metric 2.5/2.6mm don't fit then your friend may be right.Best way then is to try some american thread and see if they are correct.
brianco 17th September 2009 12:06 PM
Originally Posted by peter hawthorne (http://www.diyaudio.com/forums/analogue-source/151634-mission-774-tonearm-post1924945.html#post1924945)
It is a long time since I had one but these were most likely either AF or even BA thread. They are not metric, that I do remember. It was a good arm with high compliance cartridges such as the ADC 26 and 10EMkIV.
harwoodspark 17th September 2009 05:16 PM
The headshell on my arm had been drilled right through when I got it so I just use the common metric nuts and bolts with mine.
Salas 17th September 2009 05:35 PM
Mine is stock drilled, and I used screws from a Stanton DJ cartridge package that bolted directly, was lucky, and Stanton is American.
peter hawthorne 18th September 2009 06:00 AM
Mission 774
Thank you for your help every one I am grateful
Dennis J 5th December 2012 05:14 PM
Mission 774 Headshell threads
On my mission 774 (which I believe is virgin) the headshell blocks threads ARE
metric: 2.5 x 8 for the bolts. When I purchased it it had cut down original bolts in use that were not long enough for my Grace Ruby. I took the original bolt to my (Large) Ace hardware store that had a selection of metric bolts and one fit, groove for groove. I got the new ones home and they worked like a charm (note: slot head not socket head but who cares). Hope this helps someone.
Resources saved on this page: MySQL 18.75%
