| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
hi,
I assume that the only way to satisfyingly accommodate for MC pickups with this stage would be to use a dedicated lownoise MC-Prepre or stepup transformer. In all sims of amplification stages with this or similar topology, noise was an issue. Noise figures may be good enough for MM-pickups but not for MC-pickups. A drawback of this otherwise clever and elegant circuit. jauu Calvin
http://calvins-audio-page.jimdo.com |
#12 | |
Simple Phono Stage 2010 ![]() That version can work with either MM or MC cartridge. For a medium-output MC cartridge (~0.4-0.7mV@1kHz) the input FET J1 should be 2SK170BL, R2=68 Ohm, for a low-output MC (~0.2-0.3mV) on top of these changes R2 needs to be shunted by 1000uF 6.3V quality capacitor - that doubles the gain to ~65dB @1 kHz. The input resistor R6 should be chosen for the required cartridge load (100 Ohm - 1kOhm), R15 replaced by a wire link and I usually use C11 = 1nF for MC variants. For input FETs a selected pair should be used. Noise levels in this circuit are very good both for MM and MC. Cheers Alex Last edited by x-pro; 25th September 2012 at 11:53 PM. |
#13 | ||
.Cheers Alex |
#14 | |
Thank you very much for reply.
I see. In some cases there are no correspondence between the measurement results and the audible sonic results. The same thing you will find in follow topology: Jean Hiraga's Super Class-A Amplifier Quote:
6moons audio reviews: Acoustic System Int. HeartSong Rack Franck Tchang.com: HeartSong Racks because the unwanted microphonic effect does a too strong influential (usual and obvious at tube RIAA head amplifiers). This I don't like. If you perform a listening test (sound check) with A3i or Atac-3 include Phono Modul (RIAA operation - select "Phono") - and compare the sonic results both with and without an absorber plate like follow http://www.finite-elemente.de/de/zubehoer/soundbase or similar. Then you understand, what I mean. Last edited by tiefbassuebertr; 26th September 2012 at 02:00 PM. |
#15 | |
Cheers Alex |
#16 | |
The Outline of such an RIAA head amp looks then like the largest vintage phono stage from Plinius Audio - go to http://www.pliniusaudio.nzld.com/doc.../m14manual.pdf |
#17 | |
http://www.ant-audio.co.uk/reviews/ANT%20Kora%20LTD.pdf FYI - the A.N.T. Audio Kora 3T phono stage uses exactly the same values in the main RIAA network as the "2010" circuit. However it is a FET only design and it is still a commercial product so the circuit is not available. Cheers Alex |
#18 | |
Perhaps also similar to the OBH15 MK-II ?? Creek Audio - OBH-15mk2 |
#19 | ||
Cheers Alex |
#20 | |
One part is the resistor R2 + the forward transfer admittance. |
| Cartridges - $1000 | whubbard | Analogue Source | 42 | 30th March 2009 03:18 AM |
| audio technica cartridges | camotecue | Analogue Source | 8 | 3rd August 2008 10:56 PM |
| CD cartridges | woodturner-fran | Digital Source | 3 | 21st June 2007 07:51 PM |
| Nagaoka used cartridges | Panicos K | Analogue Source | 1 | 15th October 2006 11:40 AM |
| Old cartridges | Zero One | Analogue Source | 1 | 25th July 2006 11:22 AM |
