Old 12th September 2009, 04:30 AM   #11
vinylkid58's Avatar
There's a service manual on the vinylengine.com. You'll have to register before you can download a copy.
http://www.vinylengine.com/library/pioneer/pl-630.shtml
Jeff
Old 12th September 2009, 05:01 AM   #12
Jeff
Jeff, thanks again! Would you mind downloading and emailing it to me? The site wont allow me to get past the first register page?
Old 13th September 2009, 05:59 AM   #13
Thanks anyway Jeff! I've asked Ted if he will do it.
Old 13th September 2009, 06:14 AM   #14
The B&O's sound like they are having speed control issues (both have new belts), should I clean them? If so, what parts does one clean and how best is that done?
Old 13th September 2009, 06:26 AM   #15
Jeff
Ted cant get it either!
Can anyone please download this manual and email it to me?
Old 15th September 2009, 04:45 AM   #16
Default I made it through the cleanings of the B&O's...
I went ahead and "serviced" the Beogram 1700, if you can call it that. The platter bearing was inaccessible so all I could do was remove some heavy rubber depoits from the motor spindel with dentured alcohol and oil the tone arm shaft.
The Beogram 1800 was a surprise however, the platter bearing was accessible and it resembled a pointed steel rod received by a female brass "collar". I was able to remove the lube and regrease the bearing. The tonearm was accessible in order to oil on this model and possesed a less resistive mechanisim.
The difference between the quality of the two was amazing! The Beogram 1700 sounds like it's keeping time better, but it still generaly sounds like crap!
The Beogram 1800 is keeping fine time, and the now "lesser" level of drag on the tonearm produced a discernible sound quality improvement!
Just thought I'd post in case anyone was interested.
Old 17th September 2009, 04:39 PM   #17
kevinkr's Avatar
I'm a member of vinylengine and can definitely download manuals, contact me via pm over the next couple of days and I will try to download and send it to you.
Edit: I just downloaded the manual, let me know where to email it. Note that it is slightly over 7MB so some email accounts may find this too large an attachment. (Gmail is ok with large attachments)
www.kta-hifi.net
Old 17th September 2009, 11:07 PM   #18
Default Thanks!
Thank's Kevin! It's gent's like you who make the world a better place!
Old 18th September 2009, 10:38 PM   #19
kevinkr's Avatar
I sent you the file this morning, let me know whether or not you got it. I didn't receive any undeliverable notices so I am assuming it made it to your inbox..
www.kta-hifi.net
Old 18th September 2009, 11:02 PM   #20
john65b is offline john65b  United States
john65b's Avatar
Hello Bill,
Do you have the 1700 and 1800 both with cartridges? What is the Cartridge number? MMC1/MMC2/MMC3/MMC4/MMC5...
If I remember correctly, the 1700 and the 1800 may not use the same cartridge - the 1800 should have a cartridge like MMCx.
I have an 1800, and RX2 and a TX2. Looking for a cartridge myself - MMCx.
Let me know if you want to swap one of my TT for one of your cartridges...
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V
P17 MTM TL help on MK's alignment tables led7 Multi-Way 7 18th May 2007 10:25 AM
Using MJK´s alignment tables VelluPiri Multi-Way 2 23rd October 2006 02:22 PM
please help with MJK's alignment tables just a guy Subwoofers 61 11th August 2006 06:40 PM
MJK tables, TL size in a MTM configuration teodorom Multi-Way 0 15th April 2004 01:37 PM
Page generated in 0.10777 seconds (78.70% PHP - 21.30% MySQL) with 10 queries
