Old 29th August 2009, 04:36 AM   #1
Default Scott Radio 310
So I have in an old tube radio that I'd love to find a little more info about. I found the following site http://www.hhscott.com/the.htm but it seems to not quite fit what I have. Here's the details
Scott Radio (made in Chicago) model 310 - however, on the metal plate that lists the model and serial number, a "U" is stamped right before the '310'. Right after the '310' the letters "CA" are stamped in the metal. Serial number is 22349 if this makes any difference. The "U" and the "CA" stampings are what I'm not finding info about at the above site.
I should have asked my grandad this while he was still alive since I've wanted this radio for as long as I can remember. It looks like he built a custom case for it - it's encased in plexiglass and he built a fan and cooling vents throughout the enclosure.
Does anyone know the approximate value of this?
Old 31st August 2009, 12:39 PM   #2
gpapag is offline gpapag  Greece
gpapag's Avatar
Hi frontier
Here http://www.mcmlv.org/Archive/HiFi/Scott310E.pdf you will find the service data for this radio.
From the specifications and the schematic, I would say that this is a good radio.
Best Regards
George
Old 31st August 2009, 02:15 PM   #3
gpapag's Avatar
Hi frontier
It is quite strange, but it seems there are two different Scott Radio Model 310 around. The one which I linked to in the above post is actually a tuner (no audio power amplifier) and it was built after 1960.
Here http://www.nostalgiaair.org/PagesByM...0/M0016590.pdf you will find another Scott Radio (it has an audio power amplifier) Model 310 which was built around 1951.
Which one do you have inherited from your grandfather?
George
WTB: Scott Nixon USB DAC rca9449 Swap Meet 0 15th July 2008 05:02 AM
Scott Nixon non o/s dac nangaparbat Swap Meet 0 9th July 2008 01:44 AM
H.H Scott S 71 Xib Multi-Way 1 22nd March 2007 06:17 PM
HH Scott Transformer #s Mike K2 Tubes / Valves 1 22nd March 2007 10:07 AM
Scott amp ???? rwagter Solid State 0 8th September 2003 05:07 PM
Page generated in 0.07645 seconds (72.03% PHP - 27.97% MySQL) with 10 queries
