Simple MM only RIAA preamp - Page 3 - diyAudio
Old 19th October 2003, 02:54 PM   #21
analog_sa's Avatar
More variations - unknown japanese origin
Old 19th October 2003, 04:51 PM   #22
Onvinyl's Avatar
Konnichiwa,
quote:
Originally posted by Onvinyl
Thorsten's suggestions seem to be inspired of klaus boening's design, I think...
I think not.
hu, no offence meant. In what respects does the new circuit sound different?
Rüdiger
Old 19th October 2003, 05:35 PM   #23
Previously: Kuei Yang Wang
Konnichiwa,
We have only build this cascoded, I simply drew in the Buffers as well and re-did the RIAA as it was discussed.... The cascoded circuit with the correct RIAA sounds cleaner than the original, more open and can handle complex passages better. I normally try to leave buffers out as much as possible as they rarely improve the sound.
Sayonara
Old 19th October 2003, 06:27 PM   #24
analog_sa's Avatar
Kuei
What is your stance on splitting the riaa? If one is to have a third stage for extra gain would it be beneficial to separate the timeconstants? I seem to always prefer the sound when they're separated but usually there are way too many variables to make a direct comparison.
Old 19th October 2003, 07:08 PM   #25
Konnichiwa,
If you have three stages spliting the timeconstants can be better. Adding a stage only to split the RIAA is not a good idea however. Also, there are several ways to realise a "one go" RIAA and some sound better than others. I prefer the style applied by Kondo San in his Phonostages....
Sayonara
Old 19th October 2003, 09:48 PM   #26
Marinos is offline Marinos  Greece
Marinos's Avatar
Hi all,
Thank you for your replies
Kuei,
another setup could be
- Simple cascode for the 1st stage and subtracting the drain resistor value from the first RIAA resistor.
- Cascode + follower for the second in order to have better drive capability for the interconnects and lower output impendance.
Right ?
Adding a selector, a pot and a 3rd Cascode + Follower we have a very nice and compact (psu in a separate case) Preamplifier.
Right ?
Marinos
Old 20th October 2003, 12:14 AM   #27
Konniciwa,
Right ?
Right.
Right ?
You would need a different FET (IMHO) for the Linestage, lower transconductance and higher gate cutoff Voltage, a linestage with 36db gain re than a little excessive if you ask me....
Sayonara
Old 20th October 2003, 07:06 AM   #28
Marinos's Avatar
Default Fet Line stage
Hi kuei
Have you tried something similar?
Any suggestions for such a FET? Are the europian OK or should I search the Toshiba family ?
Could such a Line stage compete sonicaly my SE 6BX7 preamp ?
Marinos
Old 20th October 2003, 10:00 AM   #29
Werner is offline Werner  Europe
A sketch that reflects my present feelings about this kind of circuit. Optimised for the 100nF MKVs I have. YMMV.
Old 20th October 2003, 10:30 AM   #30
Electrons are yellow and more is better!
peranders's Avatar
Q1, Que? I'll gues the schematic is drawn wrong?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Needs simple RIAA pre-amp parmar664 Analogue Source 2 30th March 2007 11:29 PM
GC/RIAA (simple) preamplifer veteran Chip Amps 22 13th June 2006 09:31 PM
Simple PSU for RIAA / m-magnet lykkedk Solid State 0 16th October 2004 04:18 PM
Another Simple RIAA preamp ? CheffDeGaar Analogue Source 7 10th February 2004 11:34 AM
Simple RIAA amp from c't magazine lohk Analogue Source 46 23rd January 2003 09:44 PM
Copyright İ1999-2017 diyAudio
