Old 10th August 2009, 10:16 PM   #1
Default A Bix / Clearaudio Turntable marriage
Hi, I'm looking for some advise and guidance.
I have a Bix turntable and I have a Clearaudio Champion level II platter and bearing. What I'm planning to do is incorporate the clearaudio bearing and platter into the Bix turntable. I'm going to separate the upper and lower acrylic plinth from the Bix and install 3 spacers between them and under the lower plinth. So my table will look pretty much like a Clearaudio Champion level II when completed.
I was thinking I would make these spacers from 3 inch diameter X 2 inch thick aluminim round. The question is aluminum an acceptable material to make the spacers from or would something else be better, wood, steel, brass, lead? Should the two acrylic slabs and spacers be rigidely bolted together or just stacked and pinned. Should I incorporate any isolation between the spacers and acrylic? Does anyone know what Clearaudio does on their Level II mod?
I have a Rega 250 with the Expressimo stub, weight and vta adjuster which I will rewire for the arm. What do you think about maple for the tonearm pillar and aluminum for the arm mount?
I will be using the maxon motor, pulley and MK motor controller from the group buy here also.
Mark
unhappy marriage (oscillations) jitter Solid State 13 8th January 2009 06:47 PM
Clearaudio NANO mods tomstearns Analogue Source 1 10th November 2007 08:45 PM
The marriage btw JX92S and W3-871S Mikewong Multi-Way 7 3rd January 2007 07:22 PM
Any coment about Clearaudio Phantom tonearm? chanharvey Analogue Source 1 30th September 2005 02:46 AM
Tannoy and Aleph: happy marriage? tortello Pass Labs 3 4th October 2002 04:07 PM
Page generated in 0.08263 seconds (66.18% PHP - 33.82% MySQL) with 11 queries
