Line Level attenuation
Old 7th May 2003, 12:18 PM   #1
habana is offline habana  United Kingdom
Default Line Level attenuation
Does anyone know the resister values needed to attenuate the CD line-in on my amplifier. I want to attenuate it by about 12dB.
Thanks.
Old 8th May 2003, 09:09 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Do you know the input resistance of your amplifier?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 8th May 2003, 09:19 AM   #3
Default attenuation
Hi EC8010
I'm sorry I don't. Is that important? I was thinking along the lines of the Kimber attenuators, they are general purpose units so I understand.
Old 8th May 2003, 11:30 AM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Make a voltage divider with the ratio 1:4
10 k + 3.3k these values will work if the input impedance is >10 kohm (most likely) and if not lower the values, 5.6k + 1.8 k maybe?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 8th May 2003, 02:26 PM   #5
Default Line attenuation
Thanks for the reply.
I've actually built a passive pre amp using stepped attenuators and so the CD output goes straight into the power amps. Does this make any difference?
Excuse my ignorance but in the example you gave (10K, 3.3K) which value goes on the line and which on the return to line?
Thanks.
Old 12th May 2003, 09:35 AM   #6
dhaen is offline dhaen  Europe
dhaen's Avatar
The 10k goes in series with the line. The 3k3 goes from across the input of the preamp.
Old 12th May 2003, 10:20 AM   #7
EC8010's Avatar
It helps if you know the input resistance. The resistor values suggested will work, but the input resistance loading your CD player will be roughly 10k. Most CD players use an op-amp output stage, and most op-amps produce higher distortion into lower resistance loads. Admittedly, 10k should be just outside that range, but if you can have a higher input resistance, why not? If you had known that the input resistance of your pre-amplifier was 10k (for instance), you could have simply added a 30k series resistor, and your new input resistance would have been 40k. You might prefer to keep the input resistance constant when adding attenuators, just in case the input resistance affects the sound.
Old 12th May 2003, 10:24 AM   #8
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default atten
Don't forget that adding these largish resistors in series does worsen your signal-to-noise ratio (which will be worsened anyway by the attenuation).
I don't know any CD output stages (except possibly weakish tubed ones) that are hurt by a couple of kilo-ohms load. I would go even lower, 3k series and 1 k to gnd.
Jan Didden
Old 12th May 2003, 10:43 AM   #9
dhaen's Avatar
Default A final point...
The attenuator should be at the destination end of the cable.
Old 12th May 2003, 10:45 PM   #10
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default Brrr...
A final point...
All data given is way too vague but I understand D'haen's point when he suggested the attenuators at the end of the cable.
All in all a middle of the the road decision is called for here, vere to either end and you'll face a frequency abberation.
I agree with D'haen, best put the attenuator at the amp input.
Poor Q poor A I'm afraid,
P.S. Yet another case for transmissionline transfer theory.
Frank
Line Level attenuationHide this!Advertise here!
Convert Line Level to Electric Guitar Level miallen Instruments and Amps 4 16th May 2010 01:22 PM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
Line Level, Balanced Voltage Level... dkemppai Solid State 3 10th December 2002 11:04 PM
