combining 2 or more audio signals?
Old 6th May 2003, 09:45 PM   #1
r-wu is offline r-wu  Belgium
Default combining 2 or more audio signals?
I am running out of mixer inputs and I would like to build a merge box to make subgroups. E.g.: I would put all my fx's on 1 stereo input.
The stereo merge box needs no level control and no other goodies.
just 2 (or more) inputs -> 1 output
Is this possible without reducing the soundquality?
I found this site. http://www.hut.fi/Misc/Electronics/c...linemixer.html
Below the page there is a simple design with 10k resistors. Any thoughts on that?
thank you
[sorry if this is in wrong forum]
Old 7th May 2003, 02:27 AM   #2
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
As the text says the attenuation is high, but this may not be a problem in your application.
Better is an active summing stage as this simple mixer .
Eric.
I believe not to believe in any fixed belief system.
Old 7th May 2003, 05:23 PM   #3
i dont like the idea; because thats a small mixer.
to much work for a temporary solution.
I don't want/need volume or tone control, just a line sum
There must be a simple way to do this?
I've found this site , where there is a simple circuit using 10k resistors.
The major drawback is a 6dB attenuation.. Also the output impedance is quite low, but that should'n cause a problem.
Other suggestion?
Old 7th May 2003, 07:57 PM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
r-wu
Any passive solution will involve attenuation at some point, that is the laws of nature. If you find you run FX returns at a low level, then a passive mixer might work, as long as you have extra gain available on the desk inputs. But you will ruin your gain structure and increase noise with this solution.
I would just build the active one as per Eric's (mrfeedback), suggestion. Parts will cost very little, you could make it up in about half an hour and run it from batteries or a wall wart. You may think you just want it for one occasion, but once it's in your toolbox you will find a whole host of uses for it, believe me, i've been there
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 7th May 2003, 08:06 PM   #5
I will have to follow Eric's advice then..
Dont get me wrong, this doesn't have to be passive. I just want a clean sound, and I think I can achieve that by using as little useless controls as possible. (i really dont need the volume and tone pots)
Anyway, thanks for the advice.
If anyone has other suggestions, I haven't started building yet! ;-)
Old 7th May 2003, 08:30 PM   #6
Helix is offline Helix  United Kingdom
Helix's Avatar
Just ditch the volume pot and 15K res then, but keep C*06 and R*16.
Please be aware that this is Rod Elliott (ESP) design.
Ted
Old 7th May 2003, 10:10 PM   #7
moamps is offline moamps  Croatia
what you think about passive summing with transformers; no attenuation, good isolation, ballanced inputs and outputs..not cheap but..
http://www.jensen-transformers.com/as/as080.pdf
combining 2 or more audio signals?Hide this!Advertise here!
Combining speaker level signals (L+R, L-R) zobsky Multi-Way 5 10th August 2009 05:55 PM
Combining digital Coax Signals Darkeyce Digital Source 2 14th February 2006 07:29 AM
Switching audio signals with relay niral622 Solid State 11 19th April 2004 03:28 PM
Possible? Combining two sets of speakers for computer audio. UnknownOrigin Digital Source 0 17th March 2004 01:05 AM
Audio Signals Thru 220V Drafance007 Solid State 10 30th December 2002 07:36 PM
Copyright ©1999-2017 diyAudio
