TV PSU giving me nightmares
Old 31st July 2009, 02:40 PM   #1
Archimedes is offline Archimedes  South Africa
Archimedes's Avatar
Default TV PSU giving me nightmares
Please help
I have a Sansui SV2938T (actually an EC2938) TV that had an intermittent problem. It would be on for a while and then automatically turn off. I initally thought it was the switching IC STRS6309 that was causing the problem so I replaced it.
The problem is now the various voltages are almost a third of what they should be as soon as the PSU is reconnected to the main board. If however the 142V line is unloaded all the various voltages return to normal.
I tested the current being drawn at the 142V side when the PSU is connected to the main board and this amounts to a mere 146mA. The various voltages all seem to collapse as soon as the 142V side is connected to a load. If however any of them are left connected to the main board and only the 142V side taken off their respective voltages are correct.
As soon as the 142V side is loaded the voltages are as follows:
142V side = 56V
32V side = 14V
12V side = 4.5V
I have acquired a service repair manual over the Internet but this manual is not very helpful. It looks to be a problem with the regulation but just where to look is the issue.
I am attaching the schematic and if possible can someone please advise where the problem could be. I have already replaced all of the transistors as well as the opto. The
Old 4th August 2009, 01:26 PM   #2
Symon is offline Symon  United Kingdom
The output filter electrolitics are a favorite point of failure in switch mode supplies.
Radial capacitors freqently they show they are failing by slight swelling of the top of the can. It should be perfectly flat.
Old 6th August 2009, 02:19 PM   #3
Ghianni is offline Ghianni  Greece
Yes! Check all electrolitics and replace with low ESR ones.
Old 7th August 2009, 10:03 AM   #4
Archimedes's Avatar
I have already replaced the electrolytic on the 142V line but that did not help. I have carefully checked the other electrolytics and there vent caps are still as flat as when new. Could the transformer be a culprit?
Old 7th August 2009, 10:01 PM   #5
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
My guess would be that either the error amplifer IC802 or the feedback opto isolator has failed. So the voltage is correct off load but as soon as you draw a load there is no feedback signal to correct the output.
The other possibility is that the input bridge rectifier has lost one of its diodes. In this case it would half wave rectify which would not provide enough current on load. However I think the error amp is more likely.
You could take some measurements to see what is fed back from the error amp.
I am not a specialist with switch mode supplies so I may be wrong.
You would be better off taking this to the PSU section or trying another forum specialising in switch mode supplies where you would probably get more informative replies.
Andy.
Old 8th August 2009, 12:09 PM   #6
You have to check the caps with an ESR meter to be sure of their condition. Most of the times they "look" OK but they don't !
Old 8th August 2009, 12:20 PM   #7
sharpi31 is offline sharpi31  United Kingdom
My Loewe Xelos 32" CRT has a very similar problem. After it is first switched on, it will switch itself into standby after a couple of minutes. It repeates this two or three times, then works fine for as long as it is left switched on.
Not investigated it myself as I'd resigned myself to buying an HD flatscreen (as soon as led backlight LCDs come down in price).
I'll be interested if you find a fix though....
Old 8th August 2009, 06:46 PM   #8
infinia is offline infinia  United States
infinia's Avatar
With your o-scope monitor the PWM with the +135 disconnected and gradually increase the loading on it with a couple of 10W test resistors. The PWM is controlled by 3 output levels and CPU shutdown sig.. Look at IC802 part#?
pay atten Q802 and zener a regulator to supply 8V holdup time for CPU. ( if normal 8V output fails then Q802 is hot all of the time and load may be too much).
Old 9th August 2009, 09:53 AM   #9
A possible cure is to check the 814, 815 caps for capacitance and ESR change and then may be change both. Just a thought.
Old 24th August 2009, 08:04 PM   #10
Low Orbit is offline Low Orbit  New Zealand
Sorry about the late reply. I had a telly that was doing the same thing.
Had it fixed by a knowledgeable bloke at work - turned out to be a faulty diode - very common fault it would seem.
I'll have a chat with him today and see which one(s).
Cheers.
TV PSU giving me nightmaresHide this!Advertise here!
Turntable giving out too much treble. thelostpatrol Analogue Source 2 5th April 2007 01:49 AM
my SY CCS is only giving me 15mA Shoog Tubes / Valves 17 6th March 2006 07:43 PM
Giving them the horn? JRKO Multi-Way 7 3rd July 2004 05:49 PM
not giving up on the SOZ MEGA_amp Pass Labs 3 19th May 2004 08:33 PM
