TV PSU giving me nightmares - Page 2 - diyAudio
Old 26th August 2009, 05:26 PM   #11
Archimedes's Avatar
Hi All
After replacing most of the electrolytics I still had not managed to sort out the problem. I actually went to the point of removing the opto isolator and then noticed that the voltage immediately on switch on went up to 250V on the 142V output connected to a 656ohm/80W load (not connected to the Main board) This cleared up the possibility of a faulty transformer. You will never believe what the actual culprit was. R810 is a 0.27ohm resistor and showed no signs of being burnt or cracked and I removed it completely from the board and measured it. It turned out to be 5.1ohms Go figure!
In any event I replaced this resistor and voila everything came back to normal. The TV is now sorted out and has been running well for the last 5 days.
The lesson I learnt from this experience is that even though something looks to be in perfect condition it might not be.
Old 26th August 2009, 10:59 PM   #12
star882 is offline star882  United States
star882's Avatar
If a resistor is repeatedly cycled to or near its ratings, internal cracks may form that result in intermittent faults and increased resistance. The fix is to replace it with one a size larger.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Turntable giving out too much treble. thelostpatrol Analogue Source 2 5th April 2007 01:49 AM
my SY CCS is only giving me 15mA Shoog Tubes / Valves 17 6th March 2006 07:43 PM
Giving them the horn? JRKO Multi-Way 7 3rd July 2004 05:49 PM
not giving up on the SOZ MEGA_amp Pass Labs 3 19th May 2004 08:33 PM
Copyright 1999-2017 diyAudio
