Old 19th July 2009, 10:59 PM   #1
kilowattski's Avatar
Default My DIY Turntable is finally done
My DIY Turntable is finally done! It took two years, but I think it was worth it. It would have never happened without a lot of help and encouragement from Vinly Addict. Thank you Frank. The table has a DIY Motor Controller and is equipped with an SME IV Tonearm and Clearaudio Maestro Cartridge. In the future, I will try a Platter made from a different material, inverted bearing and different cartridge. Here are some pics.
Kilowattski
Old 19th July 2009, 11:12 PM   #2
ra7 is offline ra7  United States
wow!
Bloody awesome feat of diy engineering.
Please please tell us the details.
Old 20th July 2009, 02:41 AM   #3
directdriver's Avatar
Nice machining. Seems like the motor-pod and arm-pod are made from the same material and both are sitting on the platform the same manner. Don't vibrations travel from the motor to the arm this way? What's the concept behind the idea of completely decoupling the arm from the table? Shouldn't the arm and platter vibrate in unison if any vibration occurs? Again, impressive machining. Hope you are enjoying the sound.
Old 20th July 2009, 03:20 AM   #4
Both the motor and toneam pod are heavily damped with lead shot and silicone fluid. As you can see the turntable is mass loaded and very little vibration is transferred because the plinth is also damped with lead shot and slilcone fluid with tiptoes and the whole rack is on tiptoes on a concrete floor. I should however put an accelerometer on the table just for grins.
Kilowattski
Old 20th July 2009, 10:06 AM   #5
Awesome!
Old 20th July 2009, 11:57 AM   #6
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
What a great job
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 20th July 2009, 12:09 PM   #7
Fantastic job kilowattski!!
Are you happy with the sound?
Fran
Old 20th July 2009, 12:49 PM   #8
Yes, it is very easy on the ears. I have Jazz at the Pawn Shop on Vinyl and there are things present that I swear I have never heard before compared to CD. My next project is to come up with some sort of record cleaning device to clean all my old Vinyl.
Kilowattski
Old 20th July 2009, 02:13 PM   #9
i also see an air bearing tangential tracker in your future!
Fran
Old 20th July 2009, 02:30 PM   #10
wow
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor...
A30 - Finally! gema Pass Labs 41 29th June 2009 06:32 PM
Finally got my AT 150 Mlx duderduderini Analogue Source 0 26th December 2008 12:57 PM
finally getting going Spica Introductions 1 20th January 2008 03:57 PM
Its done finally trailsnail85 Car Audio 0 27th August 2004 07:00 PM
Finally, almost done with first IGC officeboy Chip Amps 3 11th February 2004 05:24 PM
Page generated in 0.11793 seconds (79.88% PHP - 20.12% MySQL) with 10 queries
