Old 20th July 2009, 03:19 PM   #11
directdriver's Avatar
Have you tried VHS tape? Your pulley is long enough for that. Make sure when you make the splice, cut it diagonally for smoother rotation.
Old 20th July 2009, 03:23 PM   #12
mm I tried vhs tape on mine, but I had a fair level of "rustling" which i put down to the tape flexing on the slightly crowned motor pulley. I have used reel to reel lead in tape though without any of those issues.
You can buy a length of lead in tape plus splicing kit on ebay for about $20. Enough to do a lifetime.
Fran
Old 20th July 2009, 06:37 PM   #13
audioot is offline audioot  Belgium
congratulations
mvg
audioot
Old 21st July 2009, 12:00 PM   #14
Speaking as someone who has machined his own turntable I am hugely impressed. Great job
Old 26th July 2009, 12:12 AM   #15
Very impressive exercise in machinig it looks great, you should sell the rights to Mitchel. I would only have one "constructive criticism/observation and that is, do you think that the centre of gravity is to high?? It would maybe have been perhaps more prudent to make the lower section of the platter a bit larger and to arange the hanging weights to rotate around the base unit. Thus you could get the centre of gravity much closer to the base which greatly increases stabillity and acoustic properties in my judgement. Since I am also fortunate as a model engineer to have a well equiped precision workshop, you have motivated me to seriously consider designing and building my own unit.
Old 26th July 2009, 05:44 AM   #16
kilowattski's Avatar
Actually this turntable is just my implementation on Vinyl Addict's concept. If anyone sells the concept to Mitchell, it is him. He was very kind to help me along with the table and for that I am very thankful. Frank (Vinyl Addict) is one of the most talented machinists around. For that matter, he is a pretty talented turntable designer also.
Kilowattski
Old 2nd August 2009, 06:40 PM   #17
psgr is offline psgr  United States
Hi
I don't mean to hijack this thread. I just have a question.
Is a granite plater OK for diy tt ?
If not what are the disadvantages?
Old 3rd August 2009, 10:52 AM   #18
Sure, it would work. The only caveats would be it's weight and machining the platter.
Kilowattski
Old 6th August 2009, 02:04 PM   #19
edd9000 is offline edd9000  United States
Superb.
Im about to embark on a DIY TT, care to share more details on your bearing and motor choices.
edd
Old 7th August 2009, 02:55 PM   #20
Anyone else not seeing an image of the tt?
A30 - Finally! gema Pass Labs 41 29th June 2009 05:32 PM
Finally got my AT 150 Mlx duderduderini Analogue Source 0 26th December 2008 11:57 AM
finally getting going Spica Introductions 1 20th January 2008 02:57 PM
Its done finally trailsnail85 Car Audio 0 27th August 2004 06:00 PM
Finally, almost done with first IGC officeboy Chip Amps 3 11th February 2004 04:24 PM
Page generated in 0.09467 seconds (75.02% PHP - 24.98% MySQL) with 10 queries
