| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi Everyone,
I'm thinking of building a Gedden clone for my newly acquired Linn LP12 and was looking into Toroidal transformers. I have a busted NAD 319 that wont come out of protection mode and I'm not up for fixing it myself and was quoted silly money buy a local hifi repair shop to fix it. As its just collecting dust I wondered if the massive transformer could be used as part of a Gedden clone? I tried searching on the serial number but to no avail. Can anyone help me here? |
#2 |
The geddon requires a 110VAC input Little less or more as you may vary the geddon resistor to get the right voltage output to motor. You could make some measurements and see if it can be used.
#3 | |
I was going to dive in with my multimeter, but I'm a computer engineer and the only experiance I've had with AC voltage was getting thrown across my room while trying to fix an old PSX! I was a bit worried about getting a shock if I tried to get the voltage from the wrong wires and wondered if any one knew the wiring? Should have included the serial number; its TI-61244 There is another code on it : 319/1806-2160-1 |
#4 |
The Geddon does have some AC voltage there and you'd be dealing with it for certain. I reckon anyone attempting the DIY Geddon must be armed with fundamental knowledge and intermediate skill dealing with electrics.
#5 |
I think I have enough knowledge to put this very simple circuit together safely if I bought the components new and therefore knew what wires went where! Thats not the problem. I want to keep costs down and thought it advantageous if I could recycle the most expensive component.
I also have an understanding of how the transformer works, I just have no idea what cables are for the primary and what are for the secondary. There are 6 wires coming out of the ring, 3 are of a heavier gauge. I've build and Alien DAC before, POV systems for my bike, modified just about every console that I've ever had and fixed simple faults on countless devices. All these things work off of DC or have a power pack that I've not had to build from scratch. Thought it best to ask the question on a forum about an unknown component instead of just wiring it up to the mains and seeing what comes out the other end. If I knew what wires were for each winding I think I'd be happy to build it. |
#6 |
Well I bit the bullet; got out my multi-meter, plugged in the NAD 319 and got in there.
I managed to get a reading on the primary (which seemed to be on 3 of the six wires, they were also heavier gauge) and got 250 VAC and 124 VAC. So good so far. I couldn't get a probe to the other three wires with the PSU board in situ, so I took it out and got a bit of a surprise! No wonder it wouldn't come out of Protect Mode! It had been butchered! I assume at someone has tried to repair the tracts on the board and made a pigs ear of it! Total mess and probably a hazard. I didn't want to plug it in again and the board was totally goosed so I just cut the transformer out along with the power switch on the amp, wired the 250 VAC wires to the switch and then to a wall plug and the secondary coil wires to a bit of choc block. Measured the output of the secondaries and got 94 VAC. Ace! With a couple of bits I'll be able to use the transformer. Well I was on one after that and decided to measure what the motor was getting from the existing supply. I very carefully opened the bottom of my LP12 and got my second surprise! I knew it was an old deck but the parts that made up the power supply looked ancient! There was no board. Just a piece of choc block with a large 0.22 uF cap and three other components that I couldn't read the writing on them, and that was it! I measured the output to the motor and was again surprised to find it was 112 VAC. There was a good bit of noise with just the motor running so thats probably why. With this info I thought what the heck I'll build a supply up, just to test it out and see what happens; If the motor is getting more than 110 VAC just now it wont harm it if I give it 94 VAC. All I needed was a bit of breadboard and a couple of caps. If I liked it I'll put it in a nice box and make a nice connector, but for the moment I'd just connect it all together with choc block. A quick cycle to Maplins and an ordeal with a spotty teenager later I had bought (very little) or salvaged (most of it) all the bits that I need. I put them all together, measured the output again and then connected it to the Linn. IT WORKED!!! The motor struggled to get going, creaked a bit, then ran much quieter than on the original supply. I'm listening to it just now and its definitely staying. Im not very good at describing the difference between sounds so I'm not going to try. In my opinion it sounds better so its staying. It would be nice to try and A/B test it but I don't think that there is any need. There is an audible difference in the noise coming from the motor with listening with just my ear and music is very much improved. Just need to put it in a box The ones in Maplin were rubbish!If anyone reading this has built a Geddon clone also; Is it worth putting a pot in to drop the voltage a bit more? The motor is struggling to get going just now - I've been told that very early LP12's had an heavier platter and that mine has one. I cant hear the motor anymore really - is there much more to get out of this mod? Finally, Thank you to all that have posted info on the Gedden clone, there is some great pages for this fantastic mod that's really easy after you get over the fear of getting shocked by VAC |
#7 |
I'm guessing the LP12 creaked at startup as your transformer is supplying less than the 112VAC it was getting originally. The reduced voltage now would affect the torque and a slower startup. It'll all be ok when it revs up to 33rpm.
You see, you're already in principle using another transformer to step down and supply AV voltage to the LP12 motor. In effect its also a isolating transformer which will be a lot cleaner than direct from the mains. I reckon thats the secret to a better sounding LP12. I think I've the same LP12 as yours with the simple board with 4 capacitors. The 2 bigger caps are for phase and the other to drop the voltage to the motor winding. The smaller caps are 0.01uF across the switch terminals to suppress switching noise. I've replaced the lot to modern ones. (I'd replace any cap thats 30 years old anyhow). Cheers mate! |
| why toroidal? | zafira1981 | Power Supplies | 9 | 21st December 2005 03:26 PM |
| toroidal or not toroidal | alphadelta | Solid State | 5 | 22nd November 2004 05:58 PM |
| what toroidal should be used with GC | messylife | Chip Amps | 4 | 29th April 2004 01:31 AM |
| Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) | Rixsta | Pass Labs | 10 | 23rd April 2004 04:41 AM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 09:19 PM |
| Page generated in 0.09865 seconds (88.51% PHP - 11.49% MySQL) with 10 queries |
