Originally Posted by angshudas
I tried the PVA glue, it comes out well but the crackle seem to be still there. How can I ensure that that the glue pulls out all the dirt.
Does any one have before/after sound samples.
Glue can't repair damaged records. The remaining noise may just be damage from various causes. I do dillute for easier application, but you should still use the same amount of glue as you want your dried film to be thick enough to stay together and not crack into dozens of pieces. The glue thread over at audiokarma.org has some before/after samples.
I use this method somewhat frequently. 98% of my LPs are used. I first clean with a VPI. If it's still noisy after a listen or two I put it in the noisy pile, which I then glue up in batches. It can't repair a damaged record. It can sometimes get some dirt out that other cleaning methods miss, even a VPI. So yes, it's hit or miss. Sometimes a waste of time, often not.
I found a Van Gelder stamped Lionel Hampton a week or two ago for $2. It looked OK but had a speck of cardboard stuck to it that I couldn't get off with a fingernail. Likely would have ripped my stylus off. Scrub scrub scrub on the VPI and some of the cardboard dissolved at the surface, but it was still a stylus killer. One glue treatment and it was now playable, but still heard some noise as the stylus passed that point where it was stuck, tracked fine though. Another treatment and the noise was lesser still. The rest is mostly dead quiet, a great sounding LP now. That's an exception, I mostly use it for noise reduction vs. repairs. YMMV.
BTW, I use Titebond Extend (not Extend II), which is hard to find locally (try woodworking stores), but it peels itself off as it dries.
Titebond Extend at Rockler
Rob
