Technics Turntable Auto-Return problem - Please Help !
Old 30th May 2009, 03:58 PM   #1
methoddan is offline methoddan  France
Default Technics Turntable Auto-Return problem - Please Help !
I just bought a second-hand Technics SL-BD22 semi-automatic turntable. It plays fine, sound quality is great, but I'm having a *really* annoying problem....
The auto-return happens way too soon. I haven't actually managed to lsiten to an entire song yet, as it always cuts out about 3/4 through... Maybe this has something to do with the fact that I like listening to drum'n'bass, which usually has long 6-7 minute songs, maybe the turntable is set to return after 5 because most songs aren't that long, but then, that wouldn't make sense if I was listening to a full album; and a 7" would cut out only halfway through...
Now, I might have only just gotten a turntable, but I'm not *that* stupid - I *did* read the instruction manual, and there's a little screw for adjusting the auto-return. One way makes it cut out even sooner, the other way makes it cut out later. I turned it all the way both sides (just to see) and in both cases it still cuts out way too soon...
this is extremely annoying, as I have only just gotten my turntable and was hoping to listen to all my records, but they all cut out half way... is there any way to manually adjust the auto-return so it cuts out later; or even better - to disable it, making it a sort-of manual turntable ?
Thanks a lot, I really appreciate all and any help I can get here
Dan
P.S. if nothing else works, I doubt very luch it's a good idea, but how about bending the tonearm ? I don't like that idea at all, and I don't want to break anything but I'm wondering if it's the only way...
Old 1st June 2009, 05:18 AM   #2
jazzy939 is offline jazzy939  Malaysia
jazzy939's Avatar
The cut-out/trip mechanism is just pure lever and gearing mechanism. The early tripping may be caused by 'misalignment' of the gearing, probably caused during transportation or other violent movement.
You can disable it by removing the lower cover(few screws) and disconnect the lever/trip mechanism. You know which one to disconnect when you see them moving when you move the tonearm..
Hope this helps..
Technics Turntable Auto-Return problem - Please Help !Hide this!Advertise here!
Problem with a Technics SL-D202 turntable ChopperCharles Analogue Source 4 15th February 2013 01:30 PM
Technics SL-1300 Turntable Problem AudioKid Analogue Source 7 16th May 2011 03:45 PM
turntable with auto lift for 78s Abelian Analogue Source 3 27th October 2008 06:15 PM
how to disable auto functions on DD turntable kirk57 Analogue Source 8 25th February 2008 04:39 PM
Akai AP 100C actually a P2 with auto return? G Analogue Source 0 15th September 2004 09:54 PM
Copyright ©1999-2017 diyAudio
