Old 5th September 2009, 05:28 AM   #21
frugal-phile(tm)
planet10's Avatar
One of the 1st things i do is disable the lift, so i wouldn't miss it.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th September 2009, 05:49 AM   #22
vinylkid58's Avatar
Originally Posted by TerryO View Post
Just an update on the WT turntable: Those that were at the Vancouver Island DIY Meet last weekend had the oppurtunity to hear the "Golfball" in action.
A friend of mine gave me the TT for my birthday and I took it to the "Spiritual Home" of the Odd and Offbeat: Planet10!
Please note that I'm referring to the people attending, not the gear...
Terry,
I hope there will be a return engagement for the "Golfball", somehow I missed hearing it.
Another Oddball.
Old 5th September 2009, 08:47 AM   #23
binspaul's Avatar
Send a message via Skype™ to binspaul
Dave,
Isn't that risky to operate the arm with out lift mechanism ?
Bins
Old 5th September 2009, 09:33 AM   #24
frugal-phile(tm)
planet10's Avatar
I've always found it safer to use no lift mechanism... and i get really frustrated when i run around trying to figure out why i'm not getting sound only to find out someone has put the lift up.
dave
Old 6th September 2009, 04:26 AM   #25
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Risky Business....
tonearm lifts are great for those that need them. I know lots o'folks wouldn't dream of not using one. I agree with Dave. As long as there is a tonearm rest, I'm okay without having a lift.
stew -"A sane man in an insane world appears insane."
Old 7th September 2009, 04:16 AM   #26
binspaul's Avatar
Nanook,
Nice to see you back. Any stuff for DIY tonearm lift with you ?
Bins.
Old 7th September 2009, 05:29 AM   #27
Nanook's Avatar
Default Ya, back ....move done, comp back up...
the absolute simplest idea may be something like this:
Old 8th September 2009, 04:25 PM   #28
JesseG is offline JesseG  Canada
JesseG's Avatar
Default Arm Lift on Well Tempered TT
If you think about it, you will see that it would be difficult to use a conventional arm lift on the WT tonearm, since the bearing is not 'anchored' in the horizontal plane as a conventional bearing is. Upward lift on the arm would present upward lift on the golfball, which is much lighter (intentionally) than even the bearing assembly on a unipivot arm, which relies on gravity to keep the arm from jumping off its bearing when the arm lift goes up. I expect that prototyping showed that it took the arm too long to settle back into the silicone goo after droping the arm onto the LP.
"If we crashed our cars as often as we crashed our computers, we'd all be dead!"
Old 8th September 2009, 08:24 PM   #29
Nanook's Avatar
Default Jesse...maybe something like this....
nt
Old 8th September 2009, 08:30 PM   #30
JesseG's Avatar
Good one, Stew.
That would put the lift vector against the thread holding the arm in the horizontal plane without displacing it in the vertical. Looks to me like it should work.
I am building a WT tonearm clone for one of my ultra-lite B&O based TTs, so will try this idea
Mayware / JH Labs tonearm problem Stanislav Analogue Source 12 12th January 2007 06:08 AM
DIY 47 Labs RS-A1 tonearm? or "Clonearm" maxro Analogue Source 6 14th August 2005 09:01 AM
RS Labs RS-A1 Tonearm New Unused Boxed mozfet Swap Meet 4 6th September 2004 10:51 PM
Page generated in 0.09785 seconds (79.43% PHP - 20.57% MySQL) with 11 queries
