| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#91 |
Thanks for the info ReinoutdV.
I've been eyeing some of my cf tubes again because of your recent work. I was planning on building a new tonearm with one after I finish a current project. Cutting the shafts to length neatly was always something that bothered me. I guess I can always try the dremel technique. |
#92 |
Capt Zach,
If you're asking about cutting CF to length, a cheap ($5) hardware store tube cutter worked surprisingly well on golf club shafts.
Doug Tuthill |
#93 |
Thanks for the tip dtut. I will be sure to try it on my next tonearm project.
#94 |
Please see the WTL US Patent Papers. Best regards, Bins. |
#95 |
Finally, I received the carbon shafts for the arm. I am planning to try out the 9" arm. See the attachment for the details. Also, can we use the original arm flat disc concept (as explained in the patent paper) instead of the golf ball ? Please suggest. Best regards, Bins. |
| Mayware / JH Labs tonearm problem | Stanislav | Analogue Source | 12 | 12th January 2007 06:08 AM |
| DIY 47 Labs RS-A1 tonearm? or "Clonearm" | maxro | Analogue Source | 6 | 14th August 2005 09:01 AM |
| RS Labs RS-A1 Tonearm New Unused Boxed | mozfet | Swap Meet | 4 | 6th September 2004 10:51 PM |
| Page generated in 0.08200 seconds (73.45% PHP - 26.55% MySQL) with 11 queries |
