Old 20th May 2009, 12:00 PM   #21
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Maybe the rubber belt is too small.
As for the hum, you must verify the GND connections of the tonearm.
Try to oil the motor bearings and verify if it reduces noise.
PS:
TT do not fly at all.
Ricardo
RC
Old 20th May 2009, 02:08 PM   #22
Malefoda's Avatar
Send a message via MSN to Malefoda
We can bring a CD-53 in outerspace, why not this TT in my garden?
Noise was the motor metal idler too close to motor cage. Screwed it a bit higher and it's smooth as silk and silent as a diesel submarine.
But when belt is on the story changes : the motor starts to hum a bit, too much for me (more than CD mech or the Denon... can hear it from meters away).
Anyway you can check this new video and the belt wich I feel a bit tight (and may pull the motor shaft at the top only and make it noisy...).
And it's too slow. I don't know if I would have noticed it if I did not used a speed probe but I did and as I know it I can't cope with.
So it's the belt or the metal shape on the motor wich may have lost some thickness, or both... Where may I find the REAL specifications of my TT? Many website are selling belt but who telle me they do it with a small margin in spec and therefore play at the limits?
I've checked with a simple string wich... is 677 mm when the sold one is 635 but soft and they can sell 654 ones...
Don't know!
http://www.youtube.com/watch?v=lD3YEKCGrv0
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 20th May 2009, 06:38 PM   #23
RCruz's Avatar
The belt looks too tight.
Also klean the motor puley with some alcool.
Use chalk or talk power in the belt on both sides to minimize sticking.
As for the speed, verify the voltage stettings...
Your motor is frequency locked so it is independent from the voltage fluctuations.
Also I believe your belt is touching the speed selector arm.
Otherwise it looks fine from here.
RC
Old 20th May 2009, 07:19 PM   #24
Malefoda's Avatar
I'm in touch with a Thorens Master. Seems the belt too tight is something to be real...
For the arm the clearance is ok don't worry.
Thanks Ricardo
Old 27th May 2009, 08:45 AM   #25
Malefoda's Avatar
So,
belt made loose by days on a bigger round cylinder : just works fine. Sound is far better on that Toshiba (even if all the world said nothing can beat a Thorens) than on the Denon. Smooth, fluid and well balanced. The simple arm may be a good point.
Enough for now, let's see if I'm taken by a Thorens fever or not...
Toshiba SR-630 turntable Highspeed Analogue Source 2 18th July 2009 09:30 PM
Servicing CDM 12 - Distortion auric Digital Source 7 30th September 2008 06:48 AM
Krell FPB 300c amp problem crystalchi888 Solid State 0 13th February 2008 06:16 AM
CD104 - Useful Servicing Tips poynton Digital Source 2 20th February 2006 02:03 PM
FS: Panasonic Thruster SB-300C somody Swap Meet 3 10th October 2005 03:17 PM
Page generated in 0.08295 seconds (73.17% PHP - 26.83% MySQL) with 10 queries
