| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I'm aching to try Mylar tape to drive my VPI table. But the VPI spindle is a pinch type that holds a rubber O ring in a groove. So this is not compatible with 1/4" or 1/2" mylar tape, which needs to use a flat spindle.
Anyone know of an online source for spindles that I could check out? I have a speed controller so I'm not overly worried about the outer diameter being exactly right. More the inner diameter (.1872") to fit on the motor capstan and the height of the spindle so it reaches up to where it need to to align with the platter. Thanks, Bob |
#2 |
Wow, I feel like I really stumped the experts here. No reply at all, as Phil Collins said/sang.
Surely there's got to be a source for this part, since all turntables use this. I can't believe they all have them custom manufactured. Bob |
#3 | |
If you use Mylar tape (which was very specifically designed not to stretch), you're going to discover a few problems: Getting belt tension right so that it doesn't slip will be critical. Those motor bearings are going to have far more of a load on them. I'm considering tape for a future project and have come to the conclusion that the motor will require a rebuild with better bearings, further apart, so as to withstand the side load. Not trivial.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Source for CDM 4 Spindle Motor | auric | Digital Source | 1 | 13th November 2008 04:48 PM |
| Spindle motor suddenly dead, need advice. | S.Spielbergo | Digital Source | 5 | 20th September 2008 02:41 AM |
| Turntable motor spindle is slightly bent... | Lonestar | Analogue Source | 7 | 25th February 2008 08:30 PM |
| Need spindle motor for Panasonic DVD player | Original Burnedfingers | Solid State | 10 | 25th June 2006 07:51 AM |
| Cal Audio Delta Transport Spindle Motor Help | dclu | Digital Source | 4 | 19th June 2006 07:19 PM |
| Page generated in 0.07279 seconds (70.86% PHP - 29.14% MySQL) with 10 queries |
