| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi all,
I try to make a long story short. After years of very basic hobby electronics i have reached the point where i want to fully understand circuits and develop my own too, until now i have just rebuild schematics. I use spice simulation to learn how things work, i helped to finally understand U=RI ![]() After several dissapointments with the VSPS (great sound but a noncureable noise from hell) i decided that its time for my own first phono pre circuit. After 5 days of reading and simulation I came up with a two stage opamp circuit with about 40db total gain and uses passive equalization between the gain stages, another day later i found nearly exactly the same circuit in Walt Jungs Analog Devices op amp bible (the first real book on electronics i am reading and its great, i would reconmend it to everyone who wants to get in hobby electronics). I have attached a picture of the schematic below. Before i start with the PCB design (this time i will have them professionally made) and part sourcing i have some basic questions, maybe you can help me find some answers. 1. Has anyone ever build this circuit and can share his experiences? 2. I will make a 2 layer board... ground plane or star ground? I read the chapter on grounding but remember that i read somewhere else that its the best for audio equipment to use star ground and a shielded case. 3. The resistors : Vishay CMF-55-143 ... or cheap metal films with a worse TK and accuracy but handmatched to theoretical values of reverse RIAA equilization? 3. The caps : Vishay MKP1837 0.1uF for nearly everything, handmatched selected MKP1837 for the reverse RIAA. The other option for the network: 10nF silver mica 0.3% reference capacitors + one 3nf mkp or mp and adjusted network resistors? I am afraid of mixing different cap types. Panasonic FC for the electrolytics in the PS. 4. The Opamps : AD797 since the suggested AD745 in DIP isnt available anymore. I can solder SMD, but through hole is still easier to manage especially from a desoldering point of view ![]() 5. The circuit has no bandwith limiting capacitors, i simulated it with several values for a limiting frequency from 100kHz-200kHz but the Riaa response always got pretty worse (about 0.15dB), should i implement them anyway for safety reasons? 6.The same as above for input and output highpass/lowpass filters + I dont know how the input impedance will change with an RC Network on the In / Outputs. 7. My first LC Meter ... i know you get a tool in equal in quality to the money you spend... but will an el cheapo 15 Euro LC Meter of the bay do the trick for my first "yes wife, i will measure this bag of capacitors for another 3 hours to find the best pairs" evening? 8. Is there anything i overlooked? The power supply will be the LC Audio low noise regulator, i have already built this one on breadboard and pcb and its working fine (but i dont own an oscilloscope so ... i cant really judge on the noise supression), maybe i will built another one and go complete dual mono with two seperate transformers, but thats something i can think about when the amp is up and running. Thanks for all your help. |
#2 |
You should have a look at the Nation Semiconductor data sheet for the LME49710 opamp. One of their applications is very similar. They also have an app note with other circuits you should read. I haven't built that particular circuit, but am very pleased with the LME49710 in my preamp.
I'd never go for a PCB on a preamp without breadboarding it on perf board first. Even though it won't be optimal, you'll learn things about grounding, bypassing and routing that you can apply to the PCB. This circuit is so simple there's no reason not to do so. If you can't get near zero hum and noise with perf board, you're not ready to do a PCB. Though the planes and such will help, they'd just be patching over a fundamentally flawed layout. Have you read the Hagerman (sp?) paper on RIAA turnover points and inverse networks?
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
Have a look at this :
http://www.geocities.com/rjm003.geo/.../diy_pho2.html I built something similar 6 year ago (my first DIY project), with 80dB gain (for MC), changed almost everything, including resistor and capacitor values, opamps (AD797 + OPA637), battery driven, etc. Am still using it today, but a discrete opamp version is in the making. http://www.diyaudio.com/forums/showt...02#post1488702 THEL in Germany also had something similar years ago (VP-2000, around year 2002). http://www.thel-audioworld.de/test/test.htm#VP2000 Patrick |
#4 |
Thanks for the infos,
i guess its a basic design and there is not much that can go wrong exept for ground hum and stray capacity. I will order the parts and build a dead bug circuit with some generic parts to check if its working and if everythings fine i will have the pcbs made and use close matched parts. I found some LME49721 in my free samples box i guess i will use these for the first experiments, specs look quite good.
#5 |
Good power supply is very important - not for hum but for sound quality. Plain 7815/7915 is not good enough, LM317/337 is better, shunt stabilizer is even better.
#6 |
The LC-Audio DC Reg is a dual tracking power supply ... noise rejection is about 90 DB, i think i am on the safe side with it.
I have build one on a selfdesigned PCB for my vsps and its workng fine so far ... but for the final project i will use one or two on a professionally manufactured pcb.
#7 |
Maybe you can get some samples of the LME49713 -- a very low noise CFB opamp.
#8 |
Hi Razorblade,
you wrote: 5. The circuit has no bandwith limiting capacitors, i simulated it with several values for a limiting frequency from 100kHz-200kHz but the Riaa response always got pretty worse (about 0.15dB), should i implement them anyway for safety reasons? Why do want to add frequency limiting capacitors? The RIAA itself is frequency limiting. What is important in my opinion is to match the RIAA components for the left and the right channel as close as possible. Here the link to a very interesting article. http://www.vacuumstate.com/fileupload/SP_15_Article.pdf Cheers KlausB |
#9 | ||
Thanks for all your help and suggestions, since this is my first project i really started from scratch every help is very welcome. one big problem i have : how do i calculate or simulate the load of an riaa network? When i use the original riaa values of the vsps as a passive network following a simulated Ne5532 gain stage with 23dB fed by a 1khz sin wave the output is everything but a sine wave, i guess this has to do with the load but i havn't figured it out yet. |
#10 | |
http://www.stereophile.com/features/..._equalization/ Not mentioning what I wrote years ago: http://www.tnt-audio.com/ampli/aqvox...i_part2_e.html
bring back dynamic range |
| Best overload performance RIAA opamp pre? | leadbelly | Analog Line Level | 1 | 5th February 2008 07:05 PM |
| Passively Equalized Pre-amp schematic | HKC | Solid State | 0 | 27th May 2007 10:58 AM |
| RIAA opamp phono stage advice | mp741 | Analogue Source | 19 | 7th February 2006 08:49 PM |
| Equalized passive Preamp. | promitheus | Pass Labs | 2 | 28th June 2001 06:24 PM |
