Old 29th March 2009, 10:49 AM   #1
johnm is offline johnm  United Kingdom
johnm's Avatar
Default Making a Rega P3 rotate at 16.65 RPM
Hi everyone.
Whilst suffering from the curse of insomnia one night I got to thinking how to improve the quality of LP captures onto a PC.
Being as a stylus can not be in two places at once when wriggling through those grooves (hence - I believe - the lower channel seperation compared to a CD for example), would there be any advantage to halving the speed that the record rotates to 16.65 RPM, and recording at 32-bit floating point? Then afterwards digitally speeding up the recording to the correct value before saving to 24/96 or one's preferred bit depth?
This may result in a sound quality increase as the stylus is 'flipping left and right' at the usual rate, but at a slower speed, which may - or maynot! - result in slightly more detail retrieval? Due to the slower rotational rate I believe the flywheel effect is lessened, thereby making tracking a little easier for the stylus? Hope this is making some kind of sense lol!
Regardless of the theory, I'd like to try it out. Is the best way of getting my Rega to rotate at this speed by using something like a Variac?
- John
Old 29th March 2009, 11:11 AM   #2
Wouldn't you also need to take the RIAA recording/playback curve into account.
Old 29th March 2009, 11:40 AM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
I can't help you with Rega ( not familiar with ) - but - that's old xperience that both tape and LP have better sound and measurements when speed is doubled ........ (not halved )
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 29th March 2009, 11:51 AM   #4
johnm's Avatar
Speed doubling is when for recording - more tape going past the heads and (so the theory goes) better recording quality.
Not sure about the RIAA playback needing to be adjusted... can anyone shed some light on this?
Old 29th March 2009, 02:10 PM   #5
Steerpike's Avatar
Playing back an Lp at half speed will certainly result in more accurate playback at the high end, BUT a loss in the bass end: all frequencies are halved, so if the cartridge has a response down to say 30Hz, then this means it can actually only recover frequencies down to 60Hz as recorded on the LP, once the pitch is corrected later.
The RIAA response has to be corrected too; all turnover frequencies have to be halved, i.e., time constants doubled.
Half speed mastering was common once for the advantages it gives the cutting head - the inertia of the moving parts is half as much of a problem. Same advantage with playback mechanics.
Since you are correcting the RIAA curve, you can also compensate for the unwanted bass rolloff introduced by the cartridge low end limit.
Another possible problem: turntable rumble will double in frequency, bringing it up to a more audible part of the spectrum. On a good turntable rumble will be low enough not to matter.
What drive system does the Rega use? Belt? You'd need to get a motor pulley exactly half the diameter.
I've sucessfully modified a Marantz direct drive to 16.66RPM to play my CBS extra long play discs, but then theres no pitch correction afterwards.
Old 29th March 2009, 03:24 PM   #6
johnm's Avatar
Thanks for your reply Steerpike
I hadn't realised there was so much involved, and - sadly - much of it is beyond the skills I have to implement (esp. all the RIAA correcting needed). Still maybe one day when older and wiser
- John
Old 30th March 2009, 11:40 AM   #7
Steerpike's Avatar
I don't do any LP to PC copying myself, but I have read on the WWW that there ARE various plug-ins for software like 'Audacity' that allow you do do RIAA correction afterwards in the digital domain, and that these corrections are customisable for odd playback speeds.
Old 31st March 2009, 10:48 AM   #8
bulgin is offline bulgin  South Africa
Hi
Good luck with your endeavours. OT but years ago, I have made my Rega Planar MK111 spin at 78rpm for my shellacs.
I did this by calculating the dia/circumference for a new pulley and still have it laying around.
At the time, the rubber band suspension of the motor was a real problem and I remember I also doubled-up on the rubber bands or added some extra ones.
bulgin
Old 1st April 2009, 06:12 AM   #9
Werner is offline Werner  Europe
This here can probably do the RIAA dewarping in pristine quality
(same author as of the magnificent Click Repair):
Brian Davis' Equalizer
I've tried such things a couple of years ago. It was easy enough
with a DC-motor driven GyroDec.
I could not detect any improvement in treble replay quality,
but any tiny trace of 50Hz hum, which in normal operation is
totally inaudible, stands out like a sore thumb after it has been
translated to 100Hz!
That made me stop these experiments.
Anyone interested in a custom GyroDec power supply
that can do anything between 10 and 100 rpm ?-)
bring back dynamic range
Old 1st April 2009, 02:26 PM   #10
The newest version (14.2.0) of the free program sox
http://sox.sourceforge.net/
can apply RIAA equalization digitally.
But to make this whole scheme work with sox, you must
1) connect to turntable to a preamplifier with
flat frequency response, such as a microphone preamp
2) change the sampling rate field in the sound file header
so sox thinks that it was recorded at normal 33-1/3 RPM
Regarding 2), sox may have a command-line option to
override the sampling rate of the source, so 2) might
not not be necessary.
rega p2 hum mpmarino Analogue Source 7 20th August 2006 02:38 AM
AR ES1 Rega 250 Arm Mounting tinmanrrtx Analogue Source 3 11th February 2005 09:02 PM
Can a magnetic field rotate axially? Circlotron Everything Else 10 14th November 2002 03:38 AM
Page generated in 0.11510 seconds (80.60% PHP - 19.40% MySQL) with 10 queries
