Valve Itch phono
Valve Itch phono
Old 4th August 2012, 09:34 PM   #721
woodturner-fran is offline woodturner-fran  Ireland
If you think of it as 3 different supplies:
1 x 300V
1 x 6.3
1 x 6.3
The 300V gnd and the 6.3 gnd are connected together.
The elevated heater GND is not connected to the same GND as the other 2, but rather to a point on the HV supply so that it actually floats at ~1/3 the B+. This point is made by the 2 resistors on the bottom of the PSU sch (220K, 470K). So even without the heater connected, testing voltage at this point should give you 1/3 B+. The bypass cap in parallel with the 220K stops hum.
Post a pic maybe too?
Fran
Old 4th August 2012, 09:56 PM   #722
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
1/2 B+ in the revision actually (same value resistors as in yours too).
Old 4th August 2012, 10:33 PM   #723
Yes - forgot about that, thanks Salas.
Old 5th August 2012, 11:19 AM   #724
merlin el mago is offline merlin el mago
merlin el mago's Avatar
When I connect the 150V dc elevated heaters to gnd heaters the voltage drops to 0V
Old 5th August 2012, 11:32 AM   #725
The 2 heater circuit gnds do not connect together....
"low" heater gnd connects to main circuit circuit gnd only
"high" heater gnd connects to 150v point on hv power supply only
Old 5th August 2012, 11:43 AM   #726
Originally Posted by Salas View Post
For the top halve of each totem pole only.
Fran if I understood Salas 150V goes to gnd heaters of valves V3 & V4 right? not to +6.3 heaters?
Old 5th August 2012, 12:07 PM   #727
Yes, connect the GND of the heaters for V3 and V4 to the 150V point on the HV supply. Those heaters do not connect to "normal" or circuit GND at all but that heater then "floats" above ground.
If this is done correctly, then using the DMM, measure:
Circuit GND to elevated heater GND = ~150V
Circuit GND to elevated heater POS = ~156.3V
Old 5th August 2012, 03:31 PM   #728
Fixed the issue was connected heater gnd to chassis gnd instead to leave floating, now I have the heaters elevated to 150V
Old 5th August 2012, 04:32 PM   #729
Good work merlin!
Old 5th August 2012, 08:12 PM   #730
Thanks Fran.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
